HP Calculator Simulators for Windows by Tony
04-05-2017, 10:10 PM
Tony,
I love the simulators you made and I really appreciate the fact that I can enter numbers from the PC keyboard instead of having to use the mouse. They work really well. Just one question:
I'm running them in Windows 7 and I get a bleed through in the display of whatever is behind the calculator. I've tried to attach a photo of what's happening. But whether it is the desktop icons or some other window that is behind the calculator, a little strip of the background is bleeding through at the bottom of the number display of the calculator. Any idea how I can get rid of that?
Thanks!
Bob
04-06-2017, 07:45 AM
RE: HP Calculator Simulators for Windows by Tony
(04-05-2017 10:10 PM)bshoring Wrote:  Tony,
Thanks!
I run the emulator on Linux/Wine and get the same.
04-06-2017, 09:26 AM
Thanks!
I modified the transparency code and it seems ok here.
New download available.
cheers
Tony
04-06-2017, 05:46 PM
[/quote]
cheers
Tony
[/quote]
It seems to be OK with the latest update. Thanks so much!
Love these.
Bob
04-06-2017, 06:17 PM
You've done a great job with your simulators. Thanks for your contributions to the community!
I'm running the simulators on Windows 10 and found a slight bug there.
There's no way to minimize the calculator. Normally with applications in Windows 10 that have a hidden titlebar I can shift-right-click the application in the taskbar and choose Minimize (notice that with Windows 7 there was no way to do this; with Windows XP you could do it simply by right-clicking with no need to hold shift, but Windows 7 broke this functionality). However, no menu comes up when I do this.
Emu48 had the same problem when the titlebar was hidden. I fixed it there by putting in this line of code:
#define STYLE_NOTITLE (WS_POPUP|WS_SYSMENU|WS_MINIMIZEBOX|WS_CLIPSIBLINGS)
instead of this line:
#define STYLE_NOTITLE (WS_POPUP|WS_CLIPSIBLINGS)
Perhaps a similar fix is all you need for your simulators.
04-06-2017, 08:50 PM
Tony, will there be an update to the HP-91 standalone file? I have the same bleed through on its display.
Thanks,
Bob
Bob
04-06-2017, 09:40 PM
(04-06-2017 08:50 PM)bshoring Wrote:  Tony, will there be an update to the HP-91 standalone file? I have the same bleed through on its display.
Thanks,
Bob
Just updated HP46, HP91 and HP97 which may have had the same problem
cheers
Tony
04-06-2017, 09:48 PM
(04-06-2017 06:17 PM)Eric Rechlin Wrote:  You've done a great job with your simulators. Thanks for your contributions to the community!
Hi Eric,
I didn't think minimising would be required in this type of application, but I will look into adding minimise menu item, or by keystroke.
cheers
Tony
04-07-2017, 02:40 AM
(04-06-2017 06:17 PM)Eric Rechlin Wrote:  There's no way to minimize the calculator.
I have added a Minimize menu items for CCE, HP46, HP91, HP97 and 9100B
Seems to work ok on my machine (Win7)
cheers
Tony
04-07-2017, 01:07 PM
Tony
... the date on the web page for the 46 is off by a year (2016 vs 2017)...
Great contribution, many thanks!
SlideRule
04-07-2017, 03:01 PM
Thanks for the quick turnaround. I can confirm that the minimize menu item works on Windows 10, but it's still not possible to minimize using the taskbar (either via the shift-click approach I mentioned earlier, or by simply left-clicking it while active, like you can do with any other program). I think you need to make a change similar to what I mentioned in my earlier comment to fix that.
04-07-2017, 06:00 PM
[/quote]
cheers
Tony
[/quote]
Thanks for the quick turnaround. It's good now.
Bob
Bob
04-07-2017, 09:05 PM
(04-07-2017 03:01 PM)Eric Rechlin Wrote:  Thanks for the quick turnaround. I can confirm that the minimize menu item works on Windows 10, but it's still not possible to minimize using the taskbar (either via the shift-click approach I mentioned earlier, or by simply left-clicking it while active, like you can do with any other program). I think you need to make a change similar to what I mentioned in my earlier comment to fix that.
I only have win7 so it may not be possible to do with my resources, but I'll look into it.
cheers
Tony
04-08-2017, 06:19 AM
Hi Eric,
I modified the HP-97 emulator. I can now minimize it on my Win7 machine by clicking on the task bar icon. If that works for you I will update the other programs.
cheers
Tony
04-08-2017, 03:15 PM
Thanks again, Tony. I hadn't actually tried the 97 simulator before. That thing is a beauty! Amazing job with that. I love the way the printer works.
The minimizing by clicking the taskbar button is fixed now. Thanks. Shift-right-clicking still doesn't bring up anything, but that's a very minor concern now that everything else is working.
04-08-2017, 10:31 PM
(04-08-2017 03:15 PM)Eric Rechlin Wrote:  Thanks again, Tony. I hadn't actually tried the 97 simulator before. That thing is a beauty! Amazing job with that. I love the way the printer works.
Hi Eric,
Thanks for that. I have uploaded the rest of the models.
cheers
Tony
04-09-2017, 03:32 AM
OK I'll reveal my ignorance...
Which simulators / emulators are you talking about? At which web site?
04-09-2017, 06:18 AM
(04-09-2017 03:32 AM)sa-penguin Wrote:  OK I'll reveal my ignorance...
http://www.teenix.org
cheers
Tony
04-10-2017, 11:59 AM
(04-09-2017 06:18 AM)teenix Wrote:
(04-09-2017 03:32 AM)sa-penguin Wrote:  Which simulators / emulators are you talking about? At which web site?
Ooh, nice. The 41 is my favorite (my 1st HP calc) but you have some cool stuff there.
04-16-2017, 01:21 PM
Works for me under Linux Mint 18.1 (Ubuntu 16.04) under WINE (Wine Staging 1.9.23).
