HP-67 / battery door - latch
05-13-2017, 04:13 AM
(This post was last modified: 05-13-2017 09:06 AM by Dr. Mabuse.)
Gentlemen:
I'm looking for one / a pair of these original battery door latches / door bar for my HP-67. These latches are located at the top of the battery door (top left & top right) Unfortunally one of these small green latches are gone since years. Many thanks for your help in advance ... !!! Kind regards from Germany, Thomas alias Dr. Mabuse |
05-25-2017, 05:05 PM
(This post was last modified: 05-25-2017 05:06 PM by PANAMATIK.)
RE: HP-67 / battery door - latch
Nate Martin modeled the latches for the classic battery door. But they don't fit for the HP-67. Perhaps somebody (or I) could create a 3D model for the HP-67 latches soon.
Bernhard That's one small step for a man - one giant leap for mankind. |
05-27-2017, 05:11 AM
Ok, I will try to get to the door and latches for a HP67 soon. I need to finish the battery door for a 75 first.
11-15-2023, 11:52 PM
I know this is old, BUT...
I am also looking for a replacement battery door w/latches. Any progress on this??? Mark |
11-16-2023, 05:19 AM
I am hoping to have some available soon. These will be 3D printed copies. I have a couple of samples printed in gray. I now have some military green filament that is a really good match for the original color. A friend of mine has the 3D printer, and I bought the filament to give to him, so I will check on his progress !
Cheers, John |
11-16-2023, 03:09 PM
Great news John! Keep me posted.
thx Mark |
11-17-2023, 08:54 AM
RE: HP-67 / battery door - latch | |||
11-21-2023, 11:57 PM
I'm interested too! I could use a dozen or so.
My interim solution works, but doesn't look very good. That is to take the broken latch - (assuming you have the pieces) place them together as they would be, and glue a small patch of thin plastic over the top. This connects and supports the two broken pieces. I use old collar stays. It would be great to have some replacements. -J |
11-22-2023, 12:35 AM
Mostly I need the door. Mine (from a used 67) is warped like the battery got too hot. One of the latches is broken but still sort of works. And only need one.
Mark |
12-20-2023, 12:23 AM
Johnboy - Any progress on the battery door?
Cheers! Mark |
01-15-2024, 12:50 AM
If I had a door to work from I could probably print a door with latches. I made a door for classic series recently. See photos...
https://live.staticflickr.com/65535/5346...1522_b.jpg https://live.staticflickr.com/65535/5346...9168_c.jpg https://live.staticflickr.com/65535/5346...d46d_c.jpg https://live.staticflickr.com/65535/5346...9d42_b.jpg |
02-04-2024, 04:55 PM
3D printed HP-67 door latches:
02-04-2024, 05:36 PM
Looks good! What about the door itself? That is what I need. (having them all would be best)
Thanks! Mark |
02-05-2024, 01:49 AM
(02-04-2024 04:55 PM)Dave1947 Wrote: 3D printed HP-67 door latches: These latches are excellent and work well, I'm very happy with and recommend them! --Bob Prosperi |
02-07-2024, 09:31 PM
(This post was last modified: Today 09:00 PM by Dave1947.)
(02-04-2024 05:36 PM)mbielman Wrote: Looks good! What about the door itself? That is what I need. (having them all would be best) The battery cover door is available on Shapeways site. Apparently the shapeways site no longer hosts these files. I will try to attach the stl files to another post. https://www.shapeways.com/product/LMTFVR...arketplace |
Today, 09:44 PM
Since this is apparently not available on Shapeways I'll try to attach my stl files for the HP-67 Battery Door and Latch. Should be two files contained in a .zip archive. One for the door and one for the latch. You'll need to print 2 latches for the door.
Let's see if it works. HP-67 Battery Door and Latch.zip (Size: 17.28 KB / Downloads: 2) Regards, Dave1947 |
