help: euler() prg on home mode
05-30-2017, 02:36 PM
(This post was last modified: 06-07-2017 02:59 PM by compsystems.)
Hello, the next numerical code, I want to run it in HOME MODE.
The definition v(t) does not allow me to define it within the code, Why? PHP Code: // file euler.hppprgm I managed to run it by doing the following trick. Icomment the line // v(t):= vi+(g-(c/m)*vi)*(t-ti); and I put in the line of entry (CAS MODE) the expression v(t):= vi + (g- (c / m) * vi) * (t-ti); euler() returns [] =( but [shift][1](program editor) euler [DEBUG][CONT] [enter] ...[enter] ... ok The program shows me screen by screen what I want vi=0 m/s, ti=0 s , tf=0 s v(0) = 0 m/s vi=0, ti=0, tf=2 v(2) = 19.62 m/s vi=19.62 m/s, ti=2 s, tf=4 s v(4) = 32.04 m/s vi=32.04 m/s, ti=4 s, tf=6 s v(6") = 39.90 m/s ... Please someone can help me by rewriting the above code to work well Thanks PS: In CAS mode if it works fine but how can I clean each screen? The print; command does not seem to be working. I have to clean each screen because the terminal view does not progress after the first impression screen is completed, (even hp-prime is a single process) should allow split screen and more of a process as did the hp48, PHP Code: // file euler1.hppprgm Debug mode does not work for CAS MODE = (, for this reason I want to create it in HOME MODE |
05-30-2017, 03:59 PM
(This post was last modified: 05-30-2017 04:13 PM by toml_12953.)
RE: help: euler() prg on home mode
(05-30-2017 02:36 PM)compsystems Wrote: Hello, the next numerical code, I want to run it in HOME MODE. euler (all lowercase) is a CAS function so I renamed it to EULER. Also, I'm not sure about your function definition. The following program works: Code: g;c;m;t; Tom L Cui bono? |
05-30-2017, 04:18 PM
(This post was last modified: 06-07-2017 03:06 PM by compsystems.)
Thanks toml_12953, but the file euler1.hppprgm does not clean the terminal view why?
Version calling an external function v(t) PHP Code: // file euler2.hppprgm Some alternative way for file euler2.hppprgm but without call an external function v(t) and not #cas...end prgm, I think the CAS() command is required |
05-30-2017, 05:03 PM
(05-30-2017 04:18 PM)compsystems Wrote: Thanks toml_12953, but the file euler1.hppprgm does not clean the terminal view why? Have you tried print(); instead of print; ? Tom L Tom L Cui bono? |
05-30-2017, 05:17 PM
Thanks again
The solution we do not remember print() in CASS prgm prints NULL PRINT() clears the terminal view Please HP-prime team try to solve this problem with a specific catalog for each CAS/HOME mode and, in the program editor, please check that the program names can not be compiled if it is a reserved system word Pending (home) version without subroutines of euler2.hppprgm Thanks |
