Plotter Module - PRCL command hangs in EMU41
06-02-2017, 03:45 PM (This post was last modified: 06-02-2017 03:50 PM by jch.)
In an attempt to emulate the HP-41 Plotter module in Free42 HP-IL eXtensions, I'm trying to understand how commands of the Plotter Module make use of the Input/Output buffer.
I hoped the PRCL command might help, but unfortunately, on EMU41 this command hangs the emulator.
I'd like to know if this command fails on a real HP-41 too?
Best regards.
Jean-Christophe.
Edit: update subject.
06-02-2017, 04:35 PM
RE: Plotter Module - PRCL command hangs in EMU41
(06-02-2017 03:45 PM)jch Wrote:  I hoped the PRCL command might help, but unfortunately, on EMU41 this command hangs the emulator.
I made a quick test in Emu41, that didn't hang Emu41 at all:
0 PRCL --> "PL:PLS PINIT" message. That's correct, there is no Plotter I/O buffer before PINIT.
PINIT --> "NO PLOTTER". That's correct too. But now, the Plotter I/O buffer is created.
0 PRCL --> 1.00
0 PDIR 0 PRCL --> 1.01 correct with the PDIR direction
90 PDIR 0 PRCL --> 1.10 that reflects the new PDIR direction.
25 PRCL --> alpha-string as expected.
26 PRCL --> NONEXISTENT as expected.
Are you sure you correctly loaded the 8k Plotter ROM?
J-F
06-02-2017, 08:39 PM
(06-02-2017 04:35 PM)J-F Garnier Wrote:  Are you sure you correctly loaded the 8k Plotter ROM?
Hi J-F,
NEWPLOT is running fine with PyIlper, but of course, something must be wrong.
May I have swapped both halves of the ROM? Could it be that I downloaded a bad module from TOS?
JCH.
06-03-2017, 07:21 AM
(06-02-2017 08:39 PM)jch Wrote:  NEWPLOT is running fine with PyIlper, but of course, something must be wrong.
Do you have a way to make emu41 work with pyILPER ??
For sure it will interest some people here :-)
Quote:May I have swapped both halves of the ROM? Could it be that I downloaded a bad module from TOS?
The ROM must be installed in two consecutive even-odd pages.
In Emu41, you can check that the 4k ROMs are correct with the embedded debugger:
Ctrl-Z to enter the debugger,
c command, you should get '8: 17 PL-1A OK' and '9: 18 PL-2A OK',
r to return to emulation.
J-F
06-03-2017, 09:49 AM
Yes, I have. A somewhat twisted solution, but using only straightforward pieces:
1 Virtual Box VM under DOS 6.22 to host EMU41.
1 ComOCom null modem emulator to provide a couple of serial ports, one for the VM, the other for PyIlper.
1 PyIlper configured for a serial port.
I had to use a VM with Com port redirection as this is the only way to keep an MS Dos Int14 handler in our modern world, DosEmu doesn't fully handle it
Got it!
I got '8: 18 PL-1A OK' and '9: 17 PL-2A OK', so I reversed the copy order of both ROMs, 'copy plotter2.bin /b + plotter1.bin /b plotter.bin' and now everythings' running as expected!
Many thanks, for your help and especially for all that stuff (EMU41, PIL-Box, ILPer) you bred!
JCH.
06-03-2017, 12:52 PM
(06-03-2017 09:49 AM)jch Wrote:  1 ComOCom null modem emulator to provide a couple of serial ports, one for the VM, the other for PyIlper.
I was not aware of this utility and it got me searching for the equivalent on Linux and macOS.
I have not tried it yet, but I found an interesting thread on stackoverflow: Null modem emulator (com0com) for linux
Thanks!
Sylvain
06-10-2017, 08:27 PM
I'm afraid I forgot to mention that I'm using a -slightly- modified version of PyIlper that does not check for the presence of the PIL-Box on a serial port.
