trying to display unusual matrix reboots calculator
06-28-2017, 10:58 AM
I set a matrix, m to [[1 2 3],[4 5 6],[7 8 9]]
Then I was trying to see how the at() undocumented function works. So far, I'd only used it on vectors, so I wanted to try setting position in matrix to 4, thinking it might be the first element on second row, but instead it created a 4th row equal to one element (no longer a matrix). i.e. m[4]=<99; So this just added a 4th column/row and set it to 99, so it's no longer a square matrix. When I put it in matrix mode and clicked on it, it rebooted the calculator. Why did it do that? |
06-28-2017, 11:10 AM
RE: trying to display unusual matrix reboots calculator
Try using inter-digit comma's instead of spaces...
06-28-2017, 01:29 PM
I did....CAS turns them into spaces.
06-28-2017, 01:44 PM
According to xcas documentation, at() applies to a list. Here you want to address elements of a matrix, you can address the first element on second row by m(2,1): m(2,1)=<99
06-28-2017, 05:16 PM
I know that, I'm just curious why displaying an array with 3 rows 3 wide and a 4th row only one wide causes the calculator to reboot?
06-28-2017, 05:22 PM
Actually, i said that wrong. It's when I enter shift-matrix and select this malformed matrix, it causes the system to reboot.
06-28-2017, 05:44 PM
Can you post the exact input and steps you were trying? I've been unable to see this reboot or get any malformed matrix stuff created.
Thanks! TW Although I work for HP, the views and opinions I post here are my own. |
06-28-2017, 06:29 PM
(This post was last modified: 06-28-2017 06:31 PM by DrD.)
Your OP contains the corrupted matrix:
[[1 2 3],[4 5 6],[7 8 9]] If, instead, you use: [[1,2,3],[4,5,6],[7,8,9]] You will see that your example has a syntax error, (mine works fine on my devices). Copy these and paste them into your command line to easily verify this for yourself ... You can also use: m:=[[1,2,3],[4,5,6],[7,8,9]]; |
06-28-2017, 09:17 PM
(06-28-2017 05:44 PM)Tim Wessman Wrote: Can you post the exact input and steps you were trying? I've been unable to see this reboot or get any malformed matrix stuff created. What I did was create a 3x3 matrix as in: m:=[[1 2 3][4 5 6][7 8 9]]; ....just use the matrix editor and you can make it. Then when you type m, you should get: m = 1 2 3 4 5 6 7 8 9 Next, execute the following command...make sure you are in CAS mode first... m[4]=<99; // This is actually array_sto(99,at(m,3)); This will create m = [[1 2 3][4 5 6][7 8 9]99] ...which is a malformed matrix You can go to shift-matrix scroll to m[CAS] and click on it. It will cause the reboot. I'm not too worried about it at this point. Clearly I did an illegal operation. I was assigning a scalar to a matrix row for which space was not yet created.....so it's an illegal access, which is causing a reboot. |
