Approximation of pi based on sqrt(10)
09-10-2017, 12:08 PM
RE: Approximation of pi based on sqrt(10)
(09-08-2017 08:58 PM)Dieter Wrote:This is probably closer to what everybody has in mind: significant figures(09-07-2017 07:10 PM)Thomas Okken Wrote: Not a native speaker, but what you're looking for is "decimal places." Not sure why it uses "figures" instead of "digits". |
09-11-2017, 12:25 PM
(This post was last modified: 09-11-2017 12:31 PM by Dieter.)
(09-10-2017 12:08 PM)AlexFekken Wrote:(09-08-2017 08:58 PM)Dieter Wrote: ... Yes, that's much better, I think. The Wiktionary definition seems to lack a "not": Something like "A digit that is nonzero or, when zero, followed not only by further zeros" sounds correct to me. In other words: "A digit that is nonzero or, when zero, followed by at least one non-zero". However, this still does not address the question of trailing zeros that may be significant, as discussed in the Wikipedia article. Dieter |
09-11-2017, 04:51 PM
(This post was last modified: 09-11-2017 04:53 PM by pier4r.)
(09-11-2017 12:25 PM)Dieter Wrote: Yes, that's much better, I think. The nice part on the wiki is the approach: be bold, change it, and if other people don't like it, a discussion starts. So, changed: https://en.wiktionary.org/wiki/significant_digit Now either someone else reverts the change (so a discussion over it can be started in the Talk page), or someone else improves it. In both case, it is a step closer to a better solution. wiki: - less complain + more action Wikis are great, Contribute :) |
