geometry app question...
10-15-2017, 05:34 AM
I'm trying to draw a circle, tangent to 3 lines using incircle().
I have 3 lines defined as: GA: line(y=(2*x+5)) GB: line(y=(-2*x-4)) GC: line(y=(-7*x+5)) and then I tried incircle as in: GD: incircle(GA,GB,GC) It draws the lines fine, but there is no circle on the plot screen.... What am I doing wrong? Thanks -Donald |
10-15-2017, 06:06 AM
RE: geometry app question...
On-calc help says incircle uses 3 Points rather than 3 lines.
Arno |
10-15-2017, 06:43 AM
You are right....but that's kinda screwed up, as it's supposed to draw a circle that is a tangent to 3 sides of a triangle. When I specify 3 points, I don't see the edges of the triangle....just the vertices and a circle in the middle somewhere....i.e. You can't see the tangents.
10-15-2017, 07:06 AM
(This post was last modified: 10-15-2017 07:09 AM by Didier Lachieze.)
Starting from your 3 lines you can then define the triangle vertices and draw the circle :
GA:= line(y = (2*x+5)); GB:= line(y = (-2*x-4)); GC:= line(y = (-7*x+5)); GD:= single_inter(GA,GB); GE:= single_inter(GB,GC); GG:= single_inter(GA,GC); GH:= incircle(GD,GE,GG); If you have just 3 points GA,GB,GC you can draw the triangle with triangle(GA,GB,GC) |
10-15-2017, 07:22 AM
Cool! Thank you!
-D |
10-16-2017, 02:07 PM
(This post was last modified: 10-16-2017 02:08 PM by Brad Barton.)
(10-15-2017 07:06 AM)Didier Lachieze Wrote: Starting from your 3 lines you can then define the triangle vertices and draw the circle : I tried this out today, and it looks pretty good in the plot screen. However when I try to generate the coordinates of the intersection of the circle and any one of the tangent lines, I get an imaginary result. Does this mean that the circle and the lines don't truly intersect? |
10-16-2017, 08:25 PM
(This post was last modified: 10-16-2017 08:27 PM by Arno K.)
If I remember correctly, points in geometry are represented by complex numbers.
Arno |
10-16-2017, 08:28 PM
RE: geometry app question... | |||
