Public Beta Availiable (v3) - Win/Mac/Firmware
12-12-2017, 04:57 PM
RE: Public Beta Availiable (v3) - Win/Mac/Firmware
Thanks very much for the new beta release.
I installed it on my Mac and updated my calculator without any issues at all. My 8080 simulator is running fine, so I am (still) very happy. smp |
12-12-2017, 05:20 PM
I think it is great that HP pushes out these betas. With everybody's reaction and input, it makes for a better and better product - - so here is a big thank you!
I would still like to see syst2mat() being implemented. Maybe in the next, official release? That would be nice . . . |
12-12-2017, 09:50 PM
(This post was last modified: 12-12-2017 10:28 PM by akmon.)
Updated flawlessly, thanks HP Team.
A little bug, reported in the previous release but not has been fixed: LU, qr, and Csolve commands don´t have built in help when you press help button when you are in CAS mode. Probably there could be more commands without helping, I have discovered these 3. Edit, if I write LU, QR and cSolve instead of lu, qr and csolve resp. the built in help appears. It´s curious, if you are in the catalog menu and choose those commands, it copies like lu, qr and csolve. Command works, but not the built in help. |
12-12-2017, 09:54 PM
(12-12-2017 09:50 PM)akmon Wrote: Updated flawlessly, thanks HP Team. Try this: Catalog -> LU selected -> Help idem for QR and cSolve. It works ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
12-12-2017, 10:09 PM
Thanks for the trick, this makes the bug even smaller, but it still exists.
12-12-2017, 10:11 PM
(12-12-2017 10:09 PM)akmon Wrote: Thanks for the trick, this makes the bug even smaller, but it still exists. another tip: if you have LU([matrix]) in the editing bar, select it, press Help and the help come up also... ciao Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
12-12-2017, 10:29 PM
RE: Public Beta Availiable (v3) - Win/Mac/Firmware | |||
12-12-2017, 10:58 PM
12-13-2017, 07:32 AM
As everything 'nearly' went flawless as usual and I was busy when I did the upgrade I forgot that the installer of the connectivity kit required a Windows restart when it had finished, it has been long since I saw that the last time.
Arno |
12-14-2017, 09:25 PM
Hello, I would like to share this strange crash on v3 beta version.
I attach the software that causes the crash. It´s about Morh´s circle (the program is not mine). I start the program, insert the data required, but then, after choosing option 2 "Gráfica", the physical unit turns on white screen, and there is no other way to restart the unit but inserting a clip on its back. And here is the funny thing. I run this app on the virtual calc and it works flawlessly!! For better comparison, I did a factory reset on both units, and downloaded the app, only that, for no other software could disturb it, and the results are the same I described before. 1.- ¿Can you check on your physical unit if it behaves like I wrote? 2.- What is causing this crash? It didn´t happen in version 2. |
12-15-2017, 04:19 PM
Any chance we will get an updated "user guide" .pdf with the final version?
The current one included with the virtual calculator is thoroughly out of date. Thanks |
12-15-2017, 05:47 PM
(12-15-2017 04:19 PM)Anders Wrote: Any chance we will get an updated "user guide" .pdf with the final version? When they publish it, it will be possible for you to download it: http://ftp.ftp.hp.com/pub/calculators/Pr...alculator/ Viga C | TD | FB |
12-16-2017, 01:23 PM
This might not be a bug - perhaps it is intended behaviour. It concerns the behaviour of ANS in the CAS mode.
For example: entering x^2+4, followed by d(ANS)/dx (using the derivative template) returns 2x, as it should. But, entering x^2+4, followed by ANS | x=2 (using the "with" template) just returns x^2+4 instead of the "8" that I'd expect. I'm running the latest (Beta v3) software on a real calculator. Nigel (UK) |
12-16-2017, 02:52 PM
(This post was last modified: 12-16-2017 03:05 PM by DrD.)
Did you try using Ans, instead of ANS? Then capitalization is important.
-Dale- |
12-16-2017, 03:03 PM
(12-16-2017 01:23 PM)Nigel (UK) Wrote: But, entering x^2+4, followed by ANS | x=2 (using the "with" template) just returns x^2+4 instead of the "8" that I'd expect. yes. But try Ans(2) and you get 8. See help: Ans(n) in CAS ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
12-16-2017, 04:00 PM
(12-16-2017 02:52 PM)DrD Wrote: Did you try using Ans, instead of ANS? Then capitalization is important. I used Ans, not ANS. I'm not sure why I typed the latter! If "x^2+4" is the most recent answer, Ans | x=2 simply returns x^2+4. Does this not happen on your calculator? (12-16-2017 03:03 PM)salvomic Wrote: yes. I never knew that! Thank you. But it doesn't help if I want to substitute for a variable other than x. I know that I can work around it by copying the previous line in full, so it isn't a fundamental problem, but it would be nice if Ans worked consistently. Nigel (UK) |
12-16-2017, 04:08 PM
Bonjour
ClearCell et CellHasData ne semblent pas fonctionner avec -1 en premier ou second argument. Si j'ai bien compris CellHasData(-1,1) devrait renvoyer le nombre de données dans la colonne 1 et ClearCell(2,-1) devrait effacer les cellules de la ligne 2 ? Ceci pour la calculatrice physique et l'émulateur. Hello ClearCell and CellHasData do not seem to work with -1 in first or second argument. If I understand correctly CellHasData (-1,1) should return the number of data in column 1 and ClearCell (2, -1) should clear the cells in row 2 ? This for the physical calculator and the emulator. Sorry for my english |
12-16-2017, 04:59 PM
(This post was last modified: 12-16-2017 07:55 PM by DrD.)
(12-16-2017 04:00 PM)Nigel (UK) Wrote: I used Ans, not ANS. I'm not sure why I typed the latter! If "x^2+4" is the most recent answer, Ans | x=2 simply returns x^2+4. Does this not happen on your calculator? It works for me when I tried it using Ans, on the hw and the vc, (both with r13217 firmware). It also works ok when I copy from your post and paste it in the command line: Ans | x=2, (including the spaces). -Dale- [attachment=5434] |
12-16-2017, 07:23 PM
(12-16-2017 04:59 PM)DrD Wrote:(12-16-2017 04:00 PM)Nigel (UK) Wrote: I used Ans, not ANS. I'm not sure why I typed the latter! If "x^2+4" is the most recent answer, Ans | x=2 simply returns x^2+4. Does this not happen on your calculator? How strange! My HW calculator is also r13217. This is what I do.
Do other people end up with "8"? Nigel (UK) |
12-16-2017, 07:54 PM
(This post was last modified: 12-16-2017 07:58 PM by DrD.)
I tried it your way, step by step, and worked just fine on hw and emu ...
-Dale- [attachment=5435] |
