RPN/RPL is still relevant
04-10-2014, 06:46 PM
RE: RPN/RPL is still relevant
How many people in the World do use RPN/RPL?
Is it already dead? I doubt very much that HP will continue on that path. For me, at least, HP did miss the oportunity to rebird their Calc´s business stay with a obsolet programing language. |
04-10-2014, 06:54 PM
(04-10-2014 06:39 PM)Matt Agajanian Wrote: Although I adhere to LSTx as a fine example of an error recovery tool, how do you see the efficiency and usefulness of 'Last X' on non-RPL HP's? Unless I misunderstood something, this would be simple if implemented correctly. An algebraic/textbook entry method would implement last x as "last command" so that one would simply recall the last command line and edit the mistake there. For example, I might type in \[ \frac{2x+3y-5^3}{5\sqrt{4x-1}+4} \] only to realize that the part within the square root should have been \( 4x+\pi \) and not \(4x -1 \). I simply use the "last command" (undo) feature to recall the most recent command line, have the formula above reappear, and make a minor edit. On the HP Prime, I would simply copy it from the command history with a touch of the screen. Of course, not all non-RPL HP's have this feature. In terms of keystrokes, it's still more than RPN (because one must navigate the cursor appropriately in textbook mode), but it's not irrecoverable. Graph 3D | QPI | SolveSys |
04-10-2014, 07:00 PM
(04-10-2014 06:46 PM)Alvaro Wrote: How many people in the World do use RPN/RPL? Anyone who works in finance and does a lot of number crunching (even the clerk behind your bank's counter) will likely be using RPN machines -- though not necessarily from HP. Even some cash registers operate in RPN. A new calculation starts by clearing registers to 0, and then one proceeds to add (for example) by typing in a number and pressing + and repeating with another value followed by +. Because the interface is always buttons (for each digit and the basic four operations), input efficiency is a must and there's no beating RPN when it comes to efficiency. Graph 3D | QPI | SolveSys |
04-10-2014, 07:04 PM
(This post was last modified: 04-10-2014 07:07 PM by Matt Agajanian.)
Ah, Han! I see where you're going with this.
As I've seen recently, scrolling through a history list allows a user to retrieve a full calculation, make adjustments/corrections and so forth. A very convenient undo method. So, it seems that a scrollable display, 'Ans' key, and copy/paste functionaities have enhanced the Undo option. |
04-10-2014, 07:20 PM
(This post was last modified: 04-10-2014 07:22 PM by Han.)
(04-10-2014 07:04 PM)Matt Agajanian Wrote: Ah, Han! I see where you're going with this. Indeed -- and if done right, it would not be too difficult for complete beginners to learn how to program. One idea that many folks have surely thought about is a way to save one's work on, say, the HP Prime. I propose that we go a step further and not just enable one to save their work, but to then be able to easily turn the saved "work" into a program. Since a history is kept of all calculations on the display/history stack, imagine if the user could save that history into a text file. Then the user adds in a few lines of "code" that turns those sequences of commands into program (since a program is nothing more than a sequence of commands, right?). On the HP Prime, this is just a matter of appending Code: EXPORT ProgName() <-- possibly insert some parameters, if needed An analogy would be, say, in Maple or Mathematica (or whatever other software you use as a CAS) saving the "worksheet" and then changing only a few minor parameters in the worksheet, and then re-running the worksheet. This is much, much better than keystroke programming. And, pedagogically speaking, there is a much easier transition from problem solving to programming if you introduce programming to students this way. Graph 3D | QPI | SolveSys |
