Finally acquired a Woodstock
01-13-2018, 02:19 AM
Post: #41
RE: Finally acquired a Woodstock
(01-13-2018 12:37 AM)rprosperi Wrote: Thanks for sharing your results Mark. I cut only the side with the button top in contact with the spring. That spring was nearly compressed fully, but now has about as much coil slack as the other side. The ease with which the case can be removed or inserted is very noticeable (I was pressing harder than what I felt comfortable with before surgery.) Highly recommended! ~Mark Remember kids, "In a democracy, you get the government you deserve." |
01-16-2018, 06:49 PM
Post: #42
(01-09-2018 04:04 PM)rprosperi Wrote:(01-09-2018 03:48 PM)mfleming Wrote: I'm using normal buttontop Eneloop cells and the replacement springs for the 41 battery case found on TAS. The battery holder snaps into the cavity with a nice fit and spring pressure keeps the batteries pressed tightly against the contacts inside. The holder requires a firm push downward to remove, so there's very little chance the holder will pop out of the calculator. The TAS springs use a thicker wire than the stock 41 springs and are almost fully compressed when the batteries are inserted. Hey Bob: Thanks for the link and info on the springs and contact pieces. I was trying to get my 32E working (the battery was dead and charger wouldn't make it work. SO I used a pair of Eneloops, and the contact piece I received in my order. Boy, that's a tight fit. If I rotate/jiggle the batteries, I can get the display to work correctly. If not, I only get sixes lit up in the display (top right segment in all LED numbers won't light.) I need to monkey with it some more because there really isn't room fro the Eneloops and that connector piece. At least I'll be ready for seeing if my father's woodstock will work when the 3-D printed battery holder arrives. .....Art |
01-16-2018, 06:55 PM
Post: #43
(01-13-2018 12:20 AM)mfleming Wrote:(01-10-2018 06:33 PM)larthurl Wrote: Let us know how the clipping goes. Thanks for sharing the ideas Mark. I have the batteries - Eneloops I have the springs I have the calculator Just waiting eagerly for the 3-D printer battery holder. .....Art |
01-16-2018, 09:12 PM
Post: #44
(01-16-2018 06:49 PM)larthurl Wrote: Hey Bob: Art, I'm a bit confused... this thread is primarily about Woodstocks (the battery case Mark made, the springs, etc.) but you're discussing a 32E (a Spice) - the battery mounting issues are not the same. In a Spice, batteries with the button-top are usually too tight to fit and you can easily break or damage the fragile battery tabs. Be VERY careful using these batteries as the battery bay was designed for 'flat top' cells as found in the original Spice battery holder. DO NOT USE the battery contacts that came with the springs as they are too "tall" and will likely over-stress the spring contacts in the left side (seen from back) of the 32E battery bay. Use some flat sheet metal for that contact; you can even jury-rig a contact by folding some aluminum foil several times into a 3/4" long strip. For Spice series, I would not use standard Eneloop button cells, I recommend the pre-made batteries you can find on eBay (like these), OR rebuild the original battery holder with some flat top NiCD or NiMH cells (e.g. like this) and simply wrap it with electrical tape. --Bob Prosperi |
01-17-2018, 06:23 PM
(This post was last modified: 01-17-2018 06:26 PM by larthurl.)
Post: #45
(01-16-2018 09:12 PM)rprosperi Wrote:(01-16-2018 06:49 PM)larthurl Wrote: Hey Bob: Thanks, Bob. I didn't mean to hijack the thread. The battery springs and contacts were mentioned here - and I will try to use them for the woodstock I have when the battery holder arrives.. I just shared that I tried to use the contacts (not the springs) in the 32E. Without much success. I will take your advice on the aluminum foil. Just curious, why not use ENeloops on the Spice machines? And I just ordered the pre-made battery pack from the bay that you linked to. I assume that is a rechargeable pack? .....Art |
01-17-2018, 09:03 PM
Post: #46
(01-17-2018 06:23 PM)larthurl Wrote: Just curious, why not use ENeloops on the Spice machines? Eneloops are fine from a battery power perspective, however I believe (though could be wrong) that Eneloops only come in button-top style, and would stress and likely damage the battery contacts with extended use (since they are longer, they stress the contacts). Yes, the battery pack from Waterhosko (Mark is here on the Forum from time to time) is a pair of rechargeable NiMH AA cells. The originals were much lower capacity NiCDs so this pack will definitely last longer than the original pack; I believe NiMH cells self-discharge (when not being used) a bit faster than NiCDs so its a bit of a trade-off, but your likely not buying them to just have your 32E sit in the desk drawer. Good luck and update us with your results. --Bob Prosperi |
01-22-2018, 10:41 PM
Post: #47
I just received my 1-piece Woodstock battery holders today, also using the spring-contacts noted above. Assembled and installed in less than 30 seconds. I use flat-top NiCD cells and that small difference in overall length seems to make a difference, as these fit like an original Woodstock pack, with no need to remove coils from the spring.
Thanks for sharing this design Mark! Best of all worlds - tight/secure/reliable enough to charge in the Woodstock, yet easy enough to pop batteries out for external charge with no need to re-glue the case top back on. Here's a couple pics: --Bob Prosperi |
01-23-2018, 01:45 AM
Post: #48
Now to find the perfect coloring formula to match holder to original case color!
01-23-2018, 03:04 AM
Post: #49
(01-23-2018 01:45 AM)mfleming Wrote: Now to find the perfect coloring formula to match holder to original case color! There are a lot of articles out there claiming that dyeing 3D-printed items is easy and straightforward, but I've also seen at least as many from folks claiming that it's neither of those. In this case, I suspect color-matching will be tough, since it will be trying to match plastic that has aged 30+ years, so each Woodstock is probably slightly different. But I suppose getting close to the original putty color would be a good start. Thanks again. --Bob Prosperi |
