New FIRMWARE !
02-01-2018, 08:21 PM
Post: #41
RE: New FIRMWARE !
(02-01-2018 08:11 PM)grsbanks Wrote:  Sadly there isn't that level of interest here in the UK.
In fact, if you go to HP UK's store there are only 4 machines advertised (2 financials, the 10s and the 300s), none of which is the Prime and all of which are out of stock...
Worst scenario in Italy :-(
However a good seller (also on line) in North Italy has always Prime ready to send.
Salvo
02-01-2018, 08:26 PM
Post: #42
RE: New FIRMWARE !
(02-01-2018 08:17 PM)Voldemar Wrote:
(02-01-2018 07:29 PM)striegel Wrote:  Now when I tell it to update firmware, it shows the same version it already has:
"Update firmware: 20170710"
I did download the .zip file via ftp, but how does the Conn Kit make use of this?
There is «HP Connective Kit» folder in Documents folder. There is «Firmware» folder. Delete all from «Firmware» folder. Unzip «HP_Prime_Calculator_Firmware_20180124» (13 files) to «Firmware» folder. Now You can update calculator to the latest firmware.
Or rename Firmware to something like Firmware_20170710 so you can revert (I guess!) if you have to.
02-01-2018, 08:40 PM
Post: #43
RE: New FIRMWARE !
(02-01-2018 08:26 PM)KeithB Wrote:  so you can revert (I guess!) if you have to.
I do not know is it possible to downgrade HP Prime firmware or no.
02-01-2018, 08:54 PM
Post: #44
RE: New FIRMWARE !
(02-01-2018 07:29 PM)striegel Wrote:  Since I haven't had the Prime for very long, I'm a relatively naive user of the Connectivity Kit. When I first acquired the Prime last last year, I updated the firmware using the Conn Kit.
Alan
If you're using Windows, copy all the files in the ZIP to
x:\users\username\Documents\HP Connectivity Kit\Firmware
Where x it the letter where you have your user files stored (usually C) and username is your user name. The CK looks there for the latest version.
Tom L
Cui bono?
02-01-2018, 09:27 PM
Post: #45
RE: New FIRMWARE !
(02-01-2018 08:54 PM)toml_12953 Wrote:  If you're using Windows, copy all the files in the ZIP to
Aha! I never thought to look there because I don't use the user area on my home system for anything. My practice has been to create a C:\alanstriegel directory and then put everything I care about under that.
Thanks for the pointer. Now it's running the latest firmware.
Alan
02-01-2018, 10:31 PM
Post: #46
RE: New FIRMWARE !
HP Connectivity Kit, Check for update, now appears 20180124.
