Summation based benchmark for calculators
01-29-2018, 04:44 PM
(This post was last modified: 01-29-2018 04:49 PM by Helix.)
Post: #101
RE: Summation based benchmark for calculators
Sharp PC-1401 Basic
n=10 -> 9s result: 13.71183501 n=100 -> 91s result: 139.2971873 Sharp PC-G850VS Basic n=100 -> 11s result: 139.2971873 n=1000 -> 102s result: 1395.346559 HP 50g HPGCC 2.0 - 75 Mhz n=10000 -> 2s result: 13955.85790429154 n=100000 -> 23s result: 139560.8013952589 My comments: I think the Sharp PC-1401 was the first model of this line combining a scientific calculator and a basic programmable computer, with a QWERTY keyboard. The PC-G850Vs is the very last one in this line. So it's interesting to see the evolution of speed between them. The Sharp PC-G850VS is also programmable in C, but I've not tried this possibility. We lack a good English documentation. HPGCC3 should be even faster than HPGCC 2.0, because it can switch the processor frequency up to 200 MHz. However I don't use it, because its installation and use are way too complex for me. Jean-Charles |
01-29-2018, 08:47 PM
Post: #102
added! Thanks for the report.
At first I thought "hmm, the sharp did not really improve from the first system of the line to the last". I did not see that the iterations where 10 times larger. The 50g with HPGCC2 is a little beast. Wikis are great, Contribute :) |
02-03-2018, 01:40 AM
Post: #103
Another HP 71b score, based on the program given on this thread before (and CPU freq of 655Hz!): 171s. Please correct this egregious error immediately!
02-03-2018, 10:34 PM
(This post was last modified: 02-05-2018 10:51 PM by brickviking.)
Post: #104
Here's the last results from me for a while, this should add to my previous results. First, the 9750gII upgraded to 9860gII OS running at normal speed:
These two results feature the 9750gII with the PLL jacked up to 471MHz and the CPU frequency sitting at 235 MHz (F5 in FTune):
BrickEdit: modified to add CPU frequency for the souped-up PLL. (Post 165) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
02-05-2018, 12:52 PM
(This post was last modified: 02-05-2018 12:54 PM by pier4r.)
Post: #105
(02-03-2018 01:40 AM)polbit Wrote: Another HP 71b score, based on the program given on this thread before (and CPU freq of 655Hz!): 171s. Please correct this egregious error immediately! This for 1000 iterations? edit: brickwiking. Are you sure that FTtune brings the cpu to 471mhz? I know from previous searches that the 98xx and 97xx of the casio have the cpu (SH3 IIRC) around 30 mhz, when they are pushed this varlue should reach a mximum of ~120 hmht. 470 should be really high. I'add those results asap, thanks! Wikis are great, Contribute :) |
02-05-2018, 04:48 PM
(This post was last modified: 02-05-2018 04:50 PM by toml_12953.)
Post: #106
(01-29-2018 04:44 PM)Helix Wrote: Sharp PC-1401 Basic When running benchmarks, you should normalize the results to a standard. Either make n the same for all calculators or if the results are too small to measure, increase the number of trials and then divide the results to be the equivalent. In the case above, you should divide the G850VS results by 10 and the 50g results by 1000 so they can both be directly compared to the 1401. Tom L Cui bono? |
02-06-2018, 12:46 PM
Post: #107
I guess the benchmark results are clear enough that normalization is not needed. Those results go to compete with other calculators in the same category (defined by the max x)
02-06-2018, 08:35 PM
Post: #108
results added. Please double check.
Impressive FTune although I do not know how long the system will last under overclock. http://pm.matrix.jp/ftune2e.html Surely it is pretty impressive. Wikis are great, Contribute :) |
02-06-2018, 09:31 PM
Post: #109
RE: Summation based benchmark for calculators | |||
02-06-2018, 11:56 PM
Post: #110
(02-06-2018 08:35 PM)pier4r Wrote: results added. Please double check. There's the obvious battery life reduction under overclock, but for most of these tests I used the calculator while it was plugged into the USB, so battery life wasn't adversely affected. I also noticed that overclocking this calculator in particular (can't do it with the 9750g+, no support for external plugins) led to a better response time and screen redraw time. It's all a balancing act: can I tolerate the speed I'm running at for its resultant battery life? This really applies to I/O-heavy or CPU-heavy programs, and not so much with light usage such as "waiting for slow user to respond". Still, it's nice to be able to pull out these sorts of figures against HP calculators on arbitrary benchmarks. (Post 170) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
02-25-2018, 09:22 PM
Post: #111
Casio fx-2700P
n=10 t~16s result=13.711835 n=100 t~158s result=139.29719 . |
02-25-2018, 11:47 PM
Post: #112
(02-06-2018 12:46 PM)pier4r Wrote: I guess the benchmark results are clear enough that normalization is not needed. Those results go to compete with other calculators in the same category (defined by the max x)Quite a few people have misinterpreted the data at first look. That says the results should have been normalized. Tom L Cui bono? |
02-26-2018, 07:14 AM
Post: #113
(02-25-2018 11:47 PM)toml_12953 Wrote: Quite a few people have misinterpreted the data at first look. Well a first look can be misleading, it is not really a strong justification. If people would be puzzled even after an explanation, then maybe something should change. We are talking about a simple benchmark with categories here, nothing difficult. Wikis are great, Contribute :) |
03-31-2018, 12:00 AM
Post: #114
I realize that this is not exactly a calculator per se, but I tried Free42 on my iPhone SE with iOS 11.
n = 100,000 Time = 9.19 seconds Sum = 139,560.976141 I used the same code that I used to benchmark the DM42. |
03-31-2018, 12:11 AM
Post: #115
No problem, comparisons are never bad.
100k takes 9 seconds, on an iphone? Which one? I mean which model. 6,7,8,10 ? (SE is the form factor, right?) I mean that would be interesting. I know from other threads that the free42 is quite optimized, so having the prime "only" 100% slower is quite impressive. Wikis are great, Contribute :) |
03-31-2018, 01:19 AM
(This post was last modified: 03-31-2018 01:52 AM by Michael de Estrada.)
Post: #116
(03-31-2018 12:11 AM)pier4r Wrote: 100k takes 9 seconds, on an iphone? The SE is a separate model that has the 4” screen size of the old iPhone 5, but the A9 processor of the 6s. It is currently the lowest priced model in the Apple iPhone lineup, or about a third the cost of the iPhone X. Also, I changed the angular mode to radians, and the time dropped to 7.92 seconds. An alternative code by grsbanks that uses the stack instead of saving to named variables takes 7.87 seconds. |
03-31-2018, 10:01 AM
(This post was last modified: 03-31-2018 10:01 AM by pier4r.)
Post: #117
Updated (some of the last results were missing)
http://www.hpmuseum.org/forum/thread-975...l#pid86751 http://www.wiki4hp.com/doku.php?id=bench...g_exp_root This remembers me that I have to update the "most common calculators in the forum" results since months. Good that the data is there for the moment, because I cannot allocate time to it so far. Wikis are great, Contribute :) |
04-01-2018, 01:12 AM
Post: #118
(03-31-2018 10:01 AM)pier4r Wrote: Updated (some of the last results were missing) Correction to your postings above, it should say “iPhone SE and 6s,” not “iPhone 6 SE.” The SE and 6s are different models that use the same A9 cpu. The 6 is an older model that uses a slower A8 cpu. |
04-07-2018, 10:38 AM
Post: #119
Added the casio fx C.Basic entries. I am not sure how versatile is the environment, but it is pretty quick.
08-26-2018, 06:50 PM
Post: #120
Can someone test the prime G2 with the benchmark in the first page?
(and whatever other calculator is welcomed. The more the data, the better) Wikis are great, Contribute :) |
