Loading [MathJax]/extensions/Safe.js
Estimating PI without a calculator
04-15-2014, 06:49 PM
It seems we don't need RPN.
https://medium.com/the-physics-arxiv-blog/c1eb776193ef
Just grab your pump action shotgun and use the Monte Carlo method.
04-15-2014, 07:57 PM
RE: Estimating PI without a calculator
Worked great for exams where calculators weren't permitted. I nearly got expelled/arrested trying to do e^x, though.
04-15-2014, 09:15 PM (This post was last modified: 04-15-2014 09:35 PM by everettr.)
I hear these fellows are working on a follow-up article describing their results for a variation on an old classic. The preliminary title is, "Buffon's Big Bore Blaster".
04-16-2014, 01:07 AM
Or if you just have a 4 function simple one...
An reasonably accurate estimate can be done by taking the sequence:
1 1 3 3 5 5
and putting the old division box /---- in the middle (sorry for the poor drawing but this way helps remember to process for some) so that you have:
____
113 / 355 or rather,
355
113
to get something like:
3.14159292035 (on my HP50)
On a clear disk, you can seek forever.
04-16-2014, 02:41 AM
(04-15-2014 06:49 PM)Don Williams Wrote:  It seems we don't need RPN.
Quite a drastic methodology, wouldn't you say.
Who said we can't do it with RPN?
00 { 8 Byte Prgm }
01 2
02 STO* ST Z
03 +
04 SQRT
05 STO/ ST Y
06 END
Start with:
2 ENTER
0
Then just keep hitting the [R/S] key.
04-16-2014, 02:46 AM
(04-16-2014 01:07 AM)davetheguru Wrote:  An reasonably accurate estimate can be done by taking the sequence:
1 1 3 3 5 5
For even better accuracy I tried:
1 1 3 3 5 5 7 7
Was disappointed. Huh
04-16-2014, 03:50 AM
An estimate for pi without a calculator. Using my Memory Recall function I get 3.14, or just 3 if it's been a rough week.
04-16-2014, 04:30 AM
(04-15-2014 06:49 PM)Don Williams Wrote:  Just grab your pump action shotgun and use the Monte Carlo method.
Quite appropriate in an area where shotguns are more common than RPN calculators. HP, for the sake of the nation, counteract!
04-16-2014, 04:59 PM
Quote:Then just keep hitting the [R/S] key.
No need to do that. Here's an old thread about Viete's method and a really small, self stopping program.
-katie
04-17-2014, 12:18 AM
00 { 8 Byte Prgm }
01 2
02 STO* ST Z
03 +
04 SQRT
05 STO/ ST Y
06 END
Start with:
2 ENTER
0
I'm struggling with the concept of hitting an R/S key (or any other key, for that matter) when the topic is about estimating pi WITHOUT a calculator. Just to be precise, I took my Castell-Novo Duplex 2/83N, aligned the 22 on the C scale with 7 on the D scale, moved the cursor over to the 10 on the D scale, and bold as brass on the C scale was the symbol for pi. So there...
04-17-2014, 05:15 AM
(04-17-2014 12:18 AM)JimP Wrote:  I took my Castell-Novo Duplex 2/83N
You could drop it multiple times on a cross-walk and count how often it's crossing lines:
[Image: Buffon_needle.svg]
04-19-2014, 09:29 PM
That would work with the shotgun too, when you're out of ammo, wouldn't it?
