50g - overclock
05-19-2018, 09:01 PM
(This post was last modified: 05-19-2018 09:50 PM by Vtile.)
50g - overclock
Hello
I have been trying to search the small program I remember seen somewhere in the HPCalc.org which did allow to adjust the CPU speed of the 50g. Can someone recall the name of it or do I remember incorrectly and there is no such. PS. Were there also a program that converted userRPL to sysRPL? |
05-19-2018, 09:09 PM
RE: 50g - overclock | |||
05-19-2018, 09:12 PM
RE: 50g - overclock
That is the one, many thanks.
I wonder how I didn't manage to find it. :o |
05-19-2018, 09:15 PM
RE: 50g - overclock
(05-19-2018 09:12 PM)Vtile Wrote: That is the one, many thanks. I used google http://lmgtfy.com/?q=50g+overclock |
05-19-2018, 09:49 PM
RE: 50g - overclock [solved]
It seems I would need some extra help with these Cxx programs. How I need to install them as it seems that they are not working if I just copy them to HOME or FLASH (port 2)
I'm a bit confused with these, they are not libraries so I assume I do not attach them. (05-19-2018 09:15 PM)Zaphod Wrote:(05-19-2018 09:12 PM)Vtile Wrote: That is the one, many thanks. Hah. Yes my google fu were weak. |
05-19-2018, 10:04 PM
(This post was last modified: 05-19-2018 10:05 PM by Zaphod.)
RE: 50g - overclock
From the file cat.txt, included in the download:
Quote:HP49G+ Clockspeed Adjustment Tools - HP-CAT - V2.00 |
05-19-2018, 10:18 PM
(This post was last modified: 05-19-2018 10:18 PM by Vtile.)
RE: 50g - overclock
I indeed did read that, but it doesn't give information if there is any installation requirements. The problem I'm facing is that the programs do not to seem to run properly if I do replicate the examples given as the only thing I end up with is like:
<< C124S.HP 1 1 + CFIX.HP >> EVAL results: "¤#"¤!! !" #"!"!#" 'launcher.bin' 2 "¤#"¤!! !" #"!"!#" 'launcher.bin' ... in stack. So I suppose I do miss some installation type of thing in this. |
05-20-2018, 12:38 AM
RE: 50g - overclock
I have read that this tool does not work correctly on the 50G:
http://www.hpmuseum.org/forum/thread-118...l#pid14866 Jean-Charles |
05-20-2018, 02:44 PM
RE: 50g - overclock
(05-20-2018 12:38 AM)Helix Wrote: I have read that this tool does not work correctly on the 50G: That would explain the behavior, thank you for the link. |
05-20-2018, 09:14 PM
(This post was last modified: 05-20-2018 09:32 PM by TravisE.)
RE: 50g - overclock
Vtile: Make sure the program “launcher.bin” included with those tools is in the same directory when you run those programs. Your stack output suggests it's not being found.
I've played with these tools on the 50g and found that they sort of work, but not very well. Underclocking is okay (though SLON is a bit wonky and doesn't always seem to work properly), but if I try to use anything higher than about 90–100 MHz, my calculators actually start running slower, not faster. Also, changing the clock speed seems to make TICKS behave in a very jittery way (even worse than normal operation, where it occasionally glitches already). On one of my 50g, the highest clock speeds “work”, but don't really run significantly faster. On the other 50g unit I have, they lock up the system altogether and I have to remove power to force a reboot. From what I've heard (and according to the thread Helix linked to), HPGCC(3?) handles this much better, but I'm not familiar with it and have never delved into it. Has anyone ever considered using it to create modern wrappers allowing users to change the CPU speed on the 50g properly? Is that actually doable? |
05-21-2018, 10:57 AM
RE: 50g - overclock
HPGCC3 is an entire new firmware to let run C (arm) code without the ARMtoolbox on the standard firmware.
In HPGCC2 (one could keep the 2.15 firmware in that case) you can push up or down the clock but, for what I know, still within the C code. Also while I don't like the one that says "oh why do you want to do this?", because if one wants to do something, there is always a reason, I personally wouldn't overclock the 50g while using userRPL as it wouldn't be much a gain compared to the risk. It is way better (also for personal learning and contributing to spot bugs) to install newRPL or to start to work with hpgcc / sysrpl (the first really fast but community based, the second with more documentation around plus still able to use the large RPL library, although slower than C). If one installs newRPL, aside from certain topics (like CAS), one gets a rpl environment at least 5 times faster than the userRPL if I am not mistaken. That offsets whatever overclock. Wikis are great, Contribute :) |
05-21-2018, 04:23 PM
(This post was last modified: 05-21-2018 04:41 PM by Vtile.)
RE: 50g - overclock
(05-21-2018 10:57 AM)pier4r Wrote: HPGCC3 is an entire new firmware to let run C (arm) code without the ARMtoolbox on the standard firmware.I know that the newRPL provides much more speed with almost drop in support for a userRPL (thanks to Claudios magnificent work), but this one is used for a work so I do want to have full feature set including the CAS. I only were interesting to get more speed for a few iterative calculution snippets I have build (conditional for loops).. Reading further both these comments provided kindly here and elsewhere and Alistair Borowskis original short documentation it seems pretty obvious that this is a wrong approach. While I have written a few lines of code in C, I don't seem to like it (in general), maybe I try the 'almost' obsolete HP Pascal Studio which doesn't have such a vision test and parenthesis joggling going on (try to type parenthesis with FI-keyboard and you soon hate your life.). |
05-22-2018, 04:37 AM
RE: 50g - overclock
(05-20-2018 09:14 PM)TravisE Wrote: Vtile: Make sure the program “launcher.bin” included with those tools is in the same directory when you run those programs. Your stack output suggests it's not being found. And I suspect I just found out why not. I copied my files onto a SD card (VFAT filesystem) and then onto the calculator. When doing this, the case was NOT preserved by the calculator filer, it seems to show all my files on the SD card as uppercase. Weirdly enough, renames do stick if I copy the files to main memory or to Port 2, and the case is then preserved. As TravisE suggested, make sure that LAUNCHER.BIN (if that's what you had) gets renamed to launcher.bin. Once you've done that, the rest of the programs (C124S etc) should start working as indicated. Just to pick nits, all your *.HP files should actually be *.hp, as that's what they are in the zip file. I've had freezes using TURBO too, so I may work using C124S on a vaguely regular basis. I would like to have seen a version of this that used a slider to select a single target speed from multiple speeds, and perhaps a "command to run" textbox, a "run this once" checkbox (which if empty, would simply set the speed on "Apply") and a pair of Apply/Cancel buttons. So. Varlist would be like this: Slider: SLOW, C34,48,75 (CFIX),90,101,113,119,124S,TURBO Once []: 0: set speed, run $Command if set, then exit, 1: set speed, run $command (if set), then reset speed, then exit. Command: string of command to run. Button1: Apply Button2: Cancel Any better suggestions than this? Or am I simply chasing rabbits? If you came from the South Island of New Zealand, you'd know this is a fruitless exercise, as there's far too many of them. (Post 229) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
05-26-2018, 10:06 AM
RE: 50g - overclock
(05-22-2018 04:37 AM)brickviking Wrote:Oh, nice find.(05-20-2018 09:14 PM)TravisE Wrote: Vtile: Make sure the program “launcher.bin” included with those tools is in the same directory when you run those programs. Your stack output suggests it's not being found. I can confirm that renaming the LAUNCHER.BIN to launcher.bin will remove all the errors I did report previously in this thread. C113, C119 results a crash/hang and C124S doesn't provide much speed benefit (if at all) for userRPL loop structure. C101 does corrupt at least momentarily something on the system as the softmenu and function keys doesn't match.. So not optimal outside of some obscure use case unfortunately. |
05-26-2018, 06:55 PM
RE: 50g - overclock
(05-26-2018 10:06 AM)Vtile Wrote: C113, C119 results a crash/hang and C124S doesn't provide much speed benefit (if at all) for userRPL loop structure. C101 does corrupt at least momentarily something on the system as the softmenu and function keys doesn't match.. So not optimal outside of some obscure use case unfortunately. The programs by Al Borowski were very early experiments with overclocking. The memory and other hardware clocks were going out of range sometimes and that causes instability in the form of random crashes, not exactly what you want when you need to run a long calculation. HPGCC3 has a much more advanced clocking function (also inherited by newRPL) where you can choose any clock you want, and it programs all other hardware clocks and memory wait states accordingly so it can work at 192 MHz reliably and with a real speed benefit. The bad news is the 50g OS isn't necessarily ready to operate at any clock different from the stock 75 MHz, so even if you use a C program in hpgcc3 to change the clock, some things are expected to simply not work properly. For example, USB and SD card are immediately broken in turbo mode, even though their clocks are programmed correctly. But in some drivers the OS uses fixed loops for small delays, if you make those loops run twice as fast, they don't wait long enough for the hardware to respond and causes all kinds of errors. If it had been so easy to make the 50g go faster, newRPL wouldn't exist, but the only real solution was to start from scratch. |
