PWRX 23 january version bug
01-28-2018, 10:52 AM
Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards. |
01-28-2018, 05:28 PM
RE: PWRX 23 january version bug
(01-28-2018 10:52 AM)suhast Wrote: Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine. Thanks for posting. I was going to update my CL later today, but I will hold off until hearing about this, and possibly an update to PWRX if needed. --Bob Prosperi |
01-28-2018, 05:34 PM
(01-28-2018 05:28 PM)rprosperi Wrote:(01-28-2018 10:52 AM)suhast Wrote: Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine. Maybe if someone could confirm this bug/contact Angel for a fix? Is there any manual with the latest version fixes or changes? Regards. |
01-29-2018, 12:06 AM
(01-28-2018 05:34 PM)suhast Wrote: Maybe if someone could confirm this bug/contact Angel for a fix? When Angel is free, he'll be checking here; probably within a day or two. --Bob Prosperi |
01-29-2018, 01:49 AM
The BAUD and TURBO menus dont work also, when I try using the commands in those menus it displays “no YFNX” although I have the yfnx installed
02-13-2018, 01:38 PM
Both issues have been fixed and are available on the CL library as of February 2018.
