Prime applications
04-05-2014, 08:58 PM
Prime applications
I was wondering if the standard applications were programmed with the sort of Basic language or if they were compiled from C like the rest of the firmware?
The second option was my first assumption but then I started to suspect I could be wrong. |
04-05-2014, 10:17 PM
(This post was last modified: 04-05-2014 11:00 PM by eried.)
RE: Prime applications
(04-05-2014 08:58 PM)Tugdual Wrote: I was wondering if the standard applications were programmed with the sort of Basic language or if they were compiled from C like the rest of the firmware? The user apps are just a clone of a system app one with a custom script. If you switch to any app and then open "program" you will see that the first element in the program catalog is the app itself. 100% sure that the standard apps aren't coded in basic. My website: erwin.ried.cl |
04-06-2014, 07:30 PM
(This post was last modified: 04-06-2014 07:31 PM by eried.)
Well, just to support what I thought about standard apps:
![]() ![]() By the way there are other interesting references :o inside armfir.elf: ![]() But given the language, the are maybe just garbage leftover. Sacre bleu! My website: erwin.ried.cl |
04-06-2014, 08:00 PM
Hi eried !
Please tell me, the pictures are taken from the famous ida pro software ? regards, Damien. |
04-06-2014, 08:29 PM
RE: Prime applications | |||
04-06-2014, 08:48 PM
Yes, these are from IDA. About the conversion, it is possible but highly improbable. Internal structure would look pretty messed up if it was a conversion from basic to c++. Also there are debug references to .cc files (that the linker leaves?) so the conversion is even less probable.
04-07-2014, 05:16 AM
The build in apps are all written in C-- (this is what I call c with classes, not full blown c++)... well, appart from the function and advanced graphing apps which are in c++ :-) the 3D references that you saw most likely comes from the CAS which includes a lot of things that we do not use. This probably comes from the CAS 3D geometry package. Cyrille |
04-07-2014, 04:30 PM
Good to know. It would be lovely and poetic the other way around (written in HPPPL), bootstrapping in pure expression but I guess the performance would drop immensely.
About the 3d stuff inside, you're crushing users h(?:y|o)pe cyrille! ![]() My website: erwin.ried.cl |
User(s) browsing this thread:
