how to take apart the prime
01-31-2019, 05:13 PM
Hi
I was wondering how one would go about taking apart the prime because I stupidly tried to reset it with a pencil and got the tip stuck in it so now it sometimes randomly resets Thanks |
01-31-2019, 05:34 PM
RE: how to take apart the prime
Remove the screws
My website: erwin.ried.cl |
01-31-2019, 05:43 PM
Then use the battery cover's notches to separate the upper and lower sides of the calculator without damaging them. The calculator comes with its own custom disassembly tool
01-31-2019, 06:47 PM
(This post was last modified: 01-31-2019 06:48 PM by Benjymon.)
When I took off the screws the calculator was still stuck together
Is there like Glee or a tape strip that I need to soften with heat? Thanks And I'll try the battery cover trick |
01-31-2019, 07:35 PM
There's no adhesive, the two haves are held together with plastic clips. You need to work your way in (nails worked for me, blades or edged tools tend to leave a mark).
02-01-2019, 02:28 AM
Thanks for the tips!
02-01-2019, 06:35 AM
I use a credit card angle to separate the 2 halfs... Works well... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
02-01-2019, 12:41 PM
Hi!, Benjymon :
Try too, with the procedures, indicated in images, from ... https://www.view-finder.us/Other/HP-Prim.../i-kM7X4S6 Kind Regards. informach. |
02-01-2019, 12:50 PM
I have opened my HP PRIME a while ago.
Use your nails or a plastic card or a appropriate plastic pry tool as used to open mobile devices, in order to separate the back cover. Details here: http://www.hpmuseum.org/forum/thread-537...t=internal Jose Mesquita RadioMuseum.org member |
