Integral in solve on HP 42S?
02-24-2019, 06:29 PM
If I wanted to, say, find what "x" would satisfy the integral of x^2 from 0 to x such that the area under the curve equaled 10, can this be accomplished in solve on an HP 42S?
02-24-2019, 08:13 PM
RE: Integral in solve on HP 42S?
00 { 12-Byte Prgm }
01▸LBL "f"
02 MVAR "t"
03 RCL "t"
04 X↑2
05 END
00 { 28-Byte Prgm }
01▸LBL "∫f"
02 MVAR "x"
03 RCL "x"
04 STO "ULIM"
05 PGMINT "f"
06 INTEG "t"
07 10
08 -
09 END
You can set LLIM and ACC:
0
STO "LLIM"
1e-10
STO "ACC"
And then just use the SOLVER with the program ∫f and the variable x to get
3.10723250595
02-24-2019, 08:15 PM
Easy!
Thanks.
02-25-2019, 05:17 AM
(02-24-2019 08:13 PM)Thomas Klemm Wrote:
00 { 12-Byte Prgm }
01▸LBL "f"
02 MVAR "t"
03 RCL "t"
04 X↑2
05 END
00 { 28-Byte Prgm }
01▸LBL "∫f"
02 MVAR "x"
03 RCL "x"
04 STO "ULIM"
05 PGMINT "f"
06 INTEG "t"
07 10
08 -
09 END
0
STO "LLIM"
1e-10
STO "ACC"
3.10723250595
Line 002 of programme f is not essential.
02-25-2019, 07:43 AM
(02-25-2019 05:17 AM)Gerald H Wrote:  Line 002 of programme f is not essential.
Indeed not - MVAR statements are only used by the interactive solve and integrate.
Moreover, you can replace
02 MVAR "x"
03 RCL "x"
04 STO "ULIM"
by
02 MVAR "ULIM"
straight away and solve for ULIM.
Cheers, Werner
02-25-2019, 07:47 AM
We can also drop line 05 of program ∫f:
05 PGMINT "f"
We just have to execute it once manually:
PGMINT "f"
This also allows to use the program ∫f with different functions without having to change the code.
02-25-2019, 08:09 AM
So we end up with:
00 { 9-Byte Prgm }
01▸LBL "f"
02 RCL "x"
03 X↑2
04 END
00 { 19-Byte Prgm }
01▸LBL "∫f"
02 MVAR "ULIM"
03 INTEG "x"
04 10
05 -
06 END
Example:
0
STO "LLIM"
1e-10
STO "ACC"
PGMINT "f"
Then use the SOLVER with the program ∫f and the variable ULIM to get
3.10723250595
02-26-2019, 03:15 AM
It is fun (and instructive) to see how concise coding can be accomplished. I'm always fascinated and impressed.
Wondered if the HP 42S could integrate the maximum of (f(x), g(x)) over some interval. Quite easy! For max (sin(x), cos(x)), all that was necessary was to take sin(x), x<>y, cos(x), if x>=y, RTN, x<>y, END
I will begin to try-relearn indirect addressing (last did this on an HP 67 in the 1970's when I programmed a simple baseball game...had lineups and data of 1970 American League teams on the magnetic cards, and used indirect addressing to remember where in the lineup I was at). Then, try to refresh my knowledge on the usage of flags!
02-26-2019, 03:30 AM
(02-26-2019 03:15 AM)lrdheat Wrote:  I will begin to try-relearn indirect addressing (last did this on an HP 67 in the 1970's
You're in for a treat, then! I have no experience with the HP-67 myself (I own one now, purchased on eBay, but couldn't have afforded it back when it was new), but I do have experience with the HP-19C, which is very similar. Both have only one "indirect" register, which makes a lot of algorithms awkward to implement, always having to shuffle things around to get the right pointer into register 0 (which is the I equivalent on the 19C and 29C).
Compared to that, programming the 41C, where every register, even the stack registers, can be used for indirect addressing, is so much more pleasant, and the 42S inherited that programming model.
02-26-2019, 05:30 AM
(02-26-2019 03:30 AM)Thomas Okken Wrote:  Both have only one "indirect" register, which makes a lot of algorithms awkward to implement, always having to shuffle things around to get the right pointer into register 0 (which is the I equivalent on the 19C and 29C).
From Calculator Speed Benchmark using the N-Queens Problem:
HP-67
 LBL A  CLEAR REG
        8 STO A
 LBL 0  RCL 0 RCL A
        x=y? GTO 4
        1 STO+ 0
        RCL 0 STO I
        RCL A STO(i)
 LBL 1  RCL B 1 + STO B
        RCL 0 STO 9
 LBL 2  1 STO- 9
        RCL 9 x=0? GTO 0
        RCL 0 STO I RCL(i)
        RCL 9 STO I
        Rv RCL(i) -
        x=0? GTO 3
        ABS RCL 0 RCL 9 -
        x<>y? GTO 2
 LBL 3  RCL 0 STO I
        1 STO-(i)
        RCL(i) x<>0? GTO 1
        1 STO- 0
        RCL 0 x<>0? GTO 3
 LBL 4  RCL B
        RTN
HP-41
 LBL A   CLRG
         8 STO 11
 LBL 00  RCL 00 RCL 11
         X=Y? GTO 04
         ISG 00 DEG
         STO IND 00
 LBL 01  ISG 10 DEG
         RCL 00 STO 09
 LBL 02  DSE 09 DEG
         RCL 09 X=0? GTO 00
         RCL IND 00 RCL IND 09 -
         X=0? GTO 03
         ABS RCL 00 RCL 09 -
         X<>Y? GTO 02
 LBL 03  DSE IND 00 GTO 01
         DSE 00 GTO 03
 LBL 04  RCL 10
         RTN
Compare e.g. the inner loop between LBL 2GTO 2:
HP-67
        RCL 0 STO I RCL(i)
        RCL 9 STO I
        Rv RCL(i) -
HP-41
02-26-2019, 07:41 AM
(02-25-2019 08:09 AM)Thomas Klemm Wrote:  So we end up with:
00 { 9-Byte Prgm }
01▸LBL "f"
02 RCL "x"
03 X↑2
04 END
00 { 19-Byte Prgm }
01▸LBL "∫f"
02 MVAR "ULIM"
03 INTEG "x"
04 10
05 -
06 END
Example:
0
STO "LLIM"
1e-10
STO "ACC"
PGMINT "f"
3.10723250595
It would make sense to then add ACC and LLIM as MVARS to "∫f":
00 { 30-Byte Prgm }
01▸LBL "∫f"
02 MVAR "ACC"
03 MVAR "LLIM"
04 MVAR "ULIM"
05 INTEG "x"
06 10
07 -
08 END
.. makes it a lot easier to enter the numbers, and to play with different ACC's.
Cheers, Werner
02-26-2019, 08:39 AM
(02-26-2019 07:41 AM)Werner Wrote:  It would make sense to then add ACC and LLIM as MVARS to "∫f":
00 { 30-Byte Prgm }
01▸LBL "∫f"
02 MVAR "ACC"
03 MVAR "LLIM"
04 MVAR "ULIM"
05 INTEG "x"
06 10
07 -
08 END
Cheers, Werner
Would anyone want to SOLVE for ACC though?
A useful thing to add would be the (signed) area, which is fixed at 10 in the above versions of ∫f.
— Ian Abbott
02-26-2019, 09:29 AM
This is how I did the calculation for Normal distribution.
First set accuracy by entering number of decimal digits accuracy required, eg
4
then activate FXACC
0.     { 21-Byte Prgm }
1.    ►LBL "FXACC"
2.     FIX IND ST X
3.     +/-
4.     10^X
5.     STO "ACC"
6.     CLX
7.     LASTX
8.     +/-
9.     END
to set accuracy to 0.0001
To find probability from Z value, enter Z & activate Z→P,
& to find Z value , enter P & activate P→Z.
0.     { 26-Byte Prgm }
1.    ►LBL "ΣDPREP"
2.     STO "ULIM"
3.     CLX
4.     STO "LLIM"
5.     INTEG "x"
6.     END
0.     { 96-Byte Prgm }
1.    ►LBL "NPDF"
2.     RCL "x"
3.     X^2
4.     -2
5.     ÷
6.     E^X
7.     RTN
8.    ►LBL "Z→P"
9.     PGMINT "NPDF"
10.    ►LBL 00
11.     XEQ "ΣDPREP"
12.     PI
13.     RCL+ ST X
14.     SQRT
15.     ÷
16.     0.5
17.     X<>Y
18.     -
19.     RTN
20.    ►LBL "?Z"
21.     RCL "z"
22.     XEQ 00
23.     RCL- 00
24.     RTN
25.    ►LBL "P→Z"
26.     PGMINT "NPDF"
27.     STO 00
28.     PGMSLV "?Z"
29.     4
30.     STO "z"
31.     SIGN
32.     SOLVE "z"
33.     END
User(s) browsing this thread:
