XROM for SIROM vs. EXT-IL Plus
12-29-2019, 02:54 PM
I'm on the latest CL Flash update from December. I've been searching the well documented SIROM Blueprint on TOS and was under the impression that the SIROM XROM code was 24 as confirmed by the 41CL Memory reference document. Trying to plug the EXT-IL PLUS ROM (XROM 27), I got an XROM conflict. According to this thread,, EXT-IL PLUS ROM XROM should be 27. CHKSYS and subsequent ROMLST show a conflict on XROM 27 with SIROM/EXT-IL PLUS both listed as using 27. Is it just me or can somebody else reproduce this ? Thanks Etienne |
12-29-2019, 05:02 PM
RE: XROM for SIROM vs. EXT-IL Plus
(12-29-2019 02:54 PM)Etienne Victoria Wrote: Hi all, The mem_ref is in error. SIROM is XROM 27. Sorry. |
12-29-2019, 08:53 PM
Thanks Monte,
No worries at all. The SIROM Blueprint on TOS apparently kept referring to XROM #24. I need it to be 24 so I'll change it from 27 to 24 by editing the ROM. Best Etienne |
12-30-2019, 06:20 AM
(This post was last modified: 12-30-2019 08:01 PM by Ángel Martin.)
(12-29-2019 08:53 PM)Etienne Victoria Wrote: The SIROM Blueprint on TOS apparently kept referring to XROM #24. Unfortunately that alone won't work, as there are multiple dependencies in XROM calls using #27 for id, notably SILOOP itself. So the change would need to include those as well. I don't remember changing the XROM id# revision for the SIROM but you're right the "blueprint" on TOS has #24 for id. Note however that it's dated 2012, that's quite some time ago... I should submit the current one for posting there. Best, ÁM |
12-30-2019, 06:40 PM
(This post was last modified: 12-30-2019 06:40 PM by Etienne Victoria.)
Hi Ángel,
Thanks for the information. This goes indeed beyond my YPOKEing abilities. I will find another compatible solver package. Thank you anyway for the always interesting Blueprints. Best Etienne |
