hp41cx utility function to trim an ASCII EM file
02-04-2020, 01:05 AM
Can anyone help me recall a small utility function that automatically resized an EM flle to the minimum size for its current number of records?
I thought it was in the original forum?
Thanks!
Todd
02-04-2020, 03:04 AM
RE: hp41cx utility function to trim an ASCII EM file
I believe this post may be what you are looking for?
https://www.hpmuseum.org/cgi-sys/cgiwrap...read=38991
Cheers,
Lyle
02-04-2020, 03:57 AM
You may have to adapt to fit your needs but here’s one:
https://www.hpmuseum.org/forum/thread-65...l#pid60476
André
02-04-2020, 06:03 AM (This post was last modified: 02-04-2020 06:04 AM by Ángel Martin.)
(02-04-2020 01:05 AM)twdeckard Wrote:  Can anyone help me recall a small utility function that automatically resized an EM flle to the minimum size for its current number of records?
Define "minimum number of records": all non-zero, consecutive, at the END of the file; is that it?
So the routine4 will have to start checking from the last record, counting records until finding the first non-zero value. There can be more zero records in-between that one found and the file head, but those should remain, correct?
"To live or die by your own sword one must first learn to wield it apply."
02-04-2020, 12:58 PM
(02-04-2020 03:57 AM)dayd Wrote:  You may have to adapt to fit your needs but here’s one:
André
perfect! that was it
02-05-2020, 01:50 AM
(02-04-2020 12:58 PM)twdeckard Wrote:  perfect! that was it
Well... not so perfect it seems, I found a mistake and made a little correction;
=> PKFLAS
