emu48 hp48gx serial calculator connect vspe virtual serial posts emulator
07-28-2020, 02:52 PM
I use on a windows 10/64 emu48 with a hp 48gx.
I'd like to use the hp48g calculator connect software to talk to the emulator. I use vspe - virtial serial ports emulator (latest version). I get transmission errors. Does anyone know why there are errors? What can I do? Is there another method to connect them together? Thanks for your reply |
07-28-2020, 04:41 PM
RE: emu48 hp48gx serial calculator connect vspe virtual serial posts emulator
Check this out, it usually works, though I've not tried it for this exact scenario.
http://com0com.sourceforge.net/ --Bob Prosperi |
07-28-2020, 11:34 PM
(This post was last modified: 07-28-2020 11:35 PM by Yellow.)
Thankx,
It works - Using https://www.virtual-serial-port.org . Virtial Serial Port Driver ver 9.0 build 9.0.575 by Eltima.com The Eltima software tells me that the emu48 uses 9600-N-8-2. And the connectivity kit (HP version2.3 build 2439) uses 9600-N-8-1. It would be nice if one could change it in the EMU48 with the HP 48GX. Or did I missed something in the settings in the HP48GX? I had to deselect the CTS pin in the Eltima software ver 9.0 before it worked. I could not deselect pins in the VSPE software (Eterlogic). Perhaps thats the reason why it did not work? Or has it to do with the difference between the stop bits? I have send them an email and now I'm waiting for an answer. |
07-29-2020, 12:08 AM
Well,
I wrote too soon. It does connect, but now I get errors. Humm. No idea why.... |
07-29-2020, 07:01 AM
(07-28-2020 11:34 PM)Yellow Wrote: Thankx, Bob don't meant the Eltima software, he meant com0com. I don't know what the link has to do on the com0com page. To the 2 Stop bits, the real HP48 use two stop bits, look at https://hp.giesselink.com/Pict/UART/StopBit.htm please. Two stop bits give the receiver more time to handle the received byte. |
07-29-2020, 10:55 AM
RE: emu48 hp48gx serial calculator connect vspe virtual serial posts emulator | |||
07-29-2020, 11:31 AM
User(s) browsing this thread:
