(42, all flavours) Integer Division - how?
12-11-2020, 10:48 AM
Anybody know how to implement integer division in a fast and reliable way?
And, no, / IP is not the answer.. Illustrating my point with a hypothetical 2-digit calculator, then: 79 DIV 40 = 1 200 DIV 3 = 66 890 DIV 99 = 8 2300 DIV 40 = 57 the goal is to be able to split Y=Q*X+R when possible, i.e. up to Cc00 = Qq*Xx + Rr with Cc and Rr < Xx, and Cc00 DIV Xx should give Qq (all single letters are half-length integers, or single digits in the case of the 2-digit calculator) 42S equivalents (4e11+39) DIV 40 = 1e10 (/ IP = 1e10+1) 2e12 DIV 3 = 666666666666 (666666666667) 5e23 DIV (1e12-1) = 5e11 (5e11+1) (2e23+3e12) DIV 4e11 = 5e11+7 (5e11+8) (round-to-even, and a particularly difficult one to get right) Free42 equivalents (4e33+39) DIV 40 = 1e32 2e34 DIV 3 = 666...666 I CAN do it, but it's not remotely pretty. It would be a welcome addition to Free42 ;-) Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-11-2020, 03:12 PM
RE: (42, all flavours) Integer Division - how?
This gets only your first example right on the HP-42S. So does INT÷ on the hp 33s. |
12-11-2020, 04:47 PM
(12-11-2020 10:48 AM)Werner Wrote: Anybody know how to implement integer division in a fast and reliable way? Have you tried BASE÷ ? 17bii | 32s | 32sii | 41c | 41cv | 41cx | 42s | 48g | 48g+ | 48gx | 50g | 30b |
12-11-2020, 04:56 PM
Base/ doesn’t work for 7.2 DIV 5 for instance, but also not for the Free42 examples, as it is limited to 36 bits in the 42S and 64 in Free42.
12-11-2020, 07:32 PM
(12-11-2020 10:48 AM)Werner Wrote: Anybody know how to implement integer division in a fast and reliable way? I don't know if this is fast, but FMA should work. 10 DEF FND(A,B) 20 Q=FLOOR(A/B) 30 B1=B*1000001 @ B1=B+B1-B1 @ B=B-B1 40 Q1=Q*1000001 @ Q1=Q+Q1-Q1 @ Q=Q-Q1 50 FND=FLOOR((A-Q1*B1-Q*B1-B*Q1-B*Q)/(B+B1))+Q+Q1 60 END DEF >RUN >FND(4E11+39,40) 10000000000 >FND(2E12,3) 666666666666 >FND(5E23,1E12-1) 500000000000 >FND(2E23+3E12,4E11) 500000000007 |
12-11-2020, 08:04 PM
Yes that looks like Dekker’s double precision routines. That works, but in RPN it doesn’t look quite so elegant. I was hoping there would be a shorter, simpler way.
12-11-2020, 09:28 PM
Hi.
Here is one version fulfilling the test examples on the Free42. It uses the DOT function to force calculation with all digits prior to rounding. I am not sure how reliable it actually is. It uses one extra stack level 00 {28-Byte Prgm } 01 LBL "IDIV2" 02 X<>Y 03 -0.5 04 RCLX ST Z 05 COMPLEX 06 X<>Y 07 1/X 08 ENTER 09 COMPLEX 10 DOT 11 IP 12 END Best regards Gjermund |
12-11-2020, 09:46 PM
Never too old to learn! I didn’t know DOT worked on complex numbers, too. I will have to take a look at this, but one thing’s for sure: DOT does not use extended precision, as it does in the 42S.
12-12-2020, 10:36 AM
Too bad, Gjermund: on Free42,
4e33+6 DIV 4 should be 1e33+1, and your routine returns 1e33+2 But it does work on a 42S, where DOT uses 15 intermediate digits: 4e11+6 DIV 4 = 1e11 + 1 well, - for this particular example. But since it basically does Y/X - 1/2, it fails for eg 7 DIV 3 Nevertheless, I learned something and it will be put to good use! Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-12-2020, 09:31 PM
Yeah, it turned out to be a bad idea. I also found out that the HP50g and the 42S behaves differently for the DOT and CROSS when using complex numbers for 2D. HP50g will not allow it.
best regards Gjermund |
12-13-2020, 01:24 AM
There is the "cheating" way, by temporarily setting the rounding mode
I coded mathx.setround() for this purpose PHP Code: require 'mathx' Another way is to correct the quotient of a and b (assumed both integers) Here, we assumed q, Q may have errors of ±1 a = q*b + r = q*c - q + r , where c = b+1 a = Q*c + R 0 = (q-Q)*c - q + r - R → -q + r - R ≡ 0 (mod c) Since r and R can be calculated with MOD, we can correct for q Assuming |q| < 2^53, this is the code: PHP Code: function idiv2(a,b) -- assumed b > 0 lua> a = 0x1p72 lua> for b=1e6+1, 1e6+9 do : q = idiv1(a,b) -- reference : print(b, q - floor(a/b), q - idiv2(a,b)) : end 1000001 -1 0 1000002 -1 0 1000003 -1 0 1000004 0 0 1000005 0 0 1000006 0 0 1000007 0 0 1000008 0 0 1000009 -1 0 |
12-13-2020, 08:12 AM
Yes. YES!
Thanks a million, Albert, this is what I was looking for! (the first part, cheating, doesn't apply to 41,42,Free42 of course) Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-13-2020, 12:09 PM
All that is left is to turn it in a routine..First try:
Code: { 38-Byte Prgm } @ X Y Z T I can recover b too, if needed, but that's it. Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-13-2020, 01:18 PM
(12-13-2020 01:24 AM)Albert Chan Wrote: return q + r We had assumed q never overflow, which results in |r| ≤ 1 However, if q already overflowed, calculated r is basically garbage. We should return q + sign(r), to limit the damage. In other words, if q overflow calculator precision, don't correct the quotient. |
12-13-2020, 04:21 PM
(This post was last modified: 12-13-2020 04:22 PM by Albert Chan.)
(12-13-2020 01:18 PM)Albert Chan Wrote: We had assumed q never overflow, which results in |r| ≤ 1 Assuming q is correctly rounded (mode round-to-nearest), r = 0 or -1 The code is simplified to correct, or not correct. PHP Code: function idiv3(a,b) -- assumed b > 0 |
12-13-2020, 06:41 PM
(12-13-2020 04:21 PM)Albert Chan Wrote: Assuming q is correctly rounded (mode round-to-nearest), r = 0 or -1 This allowed optimization of my FMA (Fused-Multiply-Add) code. Without using MOD, this is the fastest of all. Bonus: it removed the integer arguments requirement. PHP Code: function idiv4(a,b) -- asuumed b > 0 It would be nice if Free42 exposed FMA(a,b,c) to the user ... |
12-13-2020, 07:19 PM
(12-13-2020 04:21 PM)Albert Chan Wrote: Assuming q is correctly rounded (mode round-to-nearest), r = 0 or -1 Only for a and b positive? For a negative, it doesn’t work, eg (12 digits calc) a=-4e11-6 b=4 DIV returns -1e11-2 Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-13-2020, 07:43 PM
RE: (42, all flavours) Integer Division - how? | |||
12-13-2020, 08:51 PM
(12-13-2020 07:19 PM)Werner Wrote:(12-13-2020 04:21 PM)Albert Chan Wrote: Assuming q is correctly rounded (mode round-to-nearest), r = 0 or -1Only for a and b positive? I defined IDIV matching MOD behavior: a = b * IDIV(a,b) + MOD(a,b) Free42, binary and decimal, uses floor-mod: (a MOD b) has sign of b To match it, IDIV(a,b) = floor(a/b) So, above DIV is correct: floor((-4e11 - 6)/4) = floor(-1e11 - 1.5) = -1e11 - 2 Python also define it this way, see Why Python Integer Division Floors >>> a, b = -4*10**11-6, 4 >>> q, r = a//b, a%b >>> print q, r, q*b+r -100000000002 2 -400000000006 |
12-13-2020, 08:59 PM
Ah yes, indeed!
User(s) browsing this thread: 24 Guest(s)
