Python: some practice, questions and #%§'
05-12-2021, 09:10 PM
Now with Python I was curious what it is after all. So I decided to play a little bit around. You're of course invited to play with me. Subject is: drawing the Mandelbrot set
WARNING If you play with this, your Prime will reboot when you access an APP, definitely.
BUT this is not a great deal, you'll only lose the stack. To prevent from this, switch the Prime on and off. this will preserve the stack, but won't prevent from a reboot. That's what the "#%§'" is about. Really annoying.
I hope the moderators leave this here, because it's not meant as a great program but a playing field, to explore and exploit the capabilities of the implementation of Python on the Prime. Specifically LISTS, SETS and Drawing. Copy this code to a PPL-program. The name doesn't matter. Look at the top of the code for input syntax.
#PYTHON name
from hpprime import *
from math import *
import sys
from urandom import *
"""Get arguments Input format at HOME
          [[n]n]n.[m|0[a]]
n <depth> maximum depth of the Iteration
m <mag>   Magnitude of colors i.e. number
          of colors =mag^3 default is 4,
          giving 64 colors
a <art>   how to plot
  0:      rolling from left to right
  1:      roll by tiles
  2:      kind of dust
  3:      another dust, more random takes longer
"""parsing input. Bit tricky, <round>
and <int> needed due to binary
character. N >= 1000 results in error
inp=sys.argv[0]
inp=float(inp)
inp=modf(inp)
depth=int(max(inp[1],10))
inp=round(inp[0],2)*10
inp=modf(inp)
mag=(4 if (inp[1] <= 1 or inp[1]>6)\
    else int(inp[1]))
inp=modf(inp)
art=int(inp[1])
# set black and white
black=0x000000
white=0xffffff
""" put a pixel at x,y with color
determined by the iteration at this
specific point
def paint(x9,y9):
   z = complex(0,0)
   c = complex(3*x9/319-2*1,\
       -2.25*y9/239+1.125)
   i = 0
   while (i < depth) and abs(z) < 2:
     i = i + 1
     z = z**2+c
   rgb = pal[i%len(pal)]
   if i==depth :
     pixon(0,x9,y9,0)
   else:
     pixon(0,x9,y9,rgb)
# When finished display a small
# white square top-left
def finish():
  fillrect(0,0,0,10,10,white,white)
#clear screen black
fillrect(0,0,0,320,240,black,black)
  create color palette with
  "LIST Comprehension"  at first for
  <pal0> calculate how many elements
  for each of red, green, blue.
  then for <pal> combine each of the
  elements of one color with each
  element of the other colors.
  Thus number of colors = mag^3
elem=(255/(mag-1))
pal0=[(int(iter*elem)) for iter \
      in range(mag)]
#pal0.reverse
pal=[(b*256**2 + g*256 + r ) \
      for b in pal0 \
      for g in pal0 \
      for r in pal0]
pal.sort()
# screen filled from top to bottom,
# left to right, the simplest way
if art==0:
  for x in range(320):
    for y in range(240):
      paint(x,y)
  finish()
# Pixel put pseudo randomly,takes
# much longer. Picture completed
# by using <art1> after this loop
if art==3:
  for i in range(40**3):
   paint(randint(0,320),randint(0,240))
  art=1
# Tiles are distributed randomly and
# then filled randomly very nice,
if art==1:
 i=0
 Tiles=[]
 for TileX in range(0,320,32):
   for TileY in range(0,240,16):
       Tiles.insert(randint(0,len(Tiles)),(TileX,TileY))
 Pixels=[]
 for PixelX in range(32):
   for PixelY in range(16):
       Pixels.insert(randint(0,len(Pixels)),(PixelX,PixelY))
 P0=0
 for PixX in range(32):
   for PixY in range(16):
    px,py=Pixels[P0]
    P0+=1;
    #on the virt. prime uncomment next line
    #eval("wait(0.01")
    for t0 in range(len(Tiles)):
     tx,ty=Tiles[t0]
     paint(tx+px,ty+py)
     #paint(Tiles[t0]
 finish()
# Pixels distributed by tiles. You
# won't see a difference to <art0>
# on the Virtual Prime)
if art==2:
  t0=10
  tx=int(320/t0)
  ty=int(240/t0)
  y1=0
  for x1 in range(tx,321,tx):
    for y1 in range(ty,241,ty):
      for x in range(x1-tx,x1):
        # on the virtual Prime uncomment the next line
        #eval("Wait(0.001)")
        for y in range(y1-ty,y1):
         paint(x,y)
  finish()
eval("WAIT")
#end
EXPORT mandel(a)
BEGIN
  PYTHON(name, a);
END;
This program lives as a Python script in a PPL environment in HOME. It features 4 different kinds of output and 6 different depth of color. And it is really fast.
I'm a complete newbie to Python and inexperienced in programming, so bear with me if I talk about the obvious, but I hope to get some input as well.
Ref: #%§'
  • The reboot problem needs to be solved. has been reported
  • sys.argv errors out when value is >999
Ref: Questions, has anybody managed to:
  • get something from the mouse
  • get something from the keyboard
  • read the value of a pixel
Next step should be zooming. Therefore MOUSE or KEY events would be very helpful.
Günter
05-15-2021, 01:04 AM
RE: Python: some practice, questions and #%§'
I seem to have some success with the following snippet in PPL:
#PYTHON EXPORT mktest()
from math import *
# haven't found terminal screen clear yet
print("""Perform one of the following:
1. position mouse pointer on screen and then double-touch
2. click a calculator key
3. press 'On' to exit""")
lastm,lastk=0,0
while 1:
  # gets 2nd pair of coords (2-touch)
  # move mouse ptr around screen and double touch
  m=mouse()[1]
  k=keyboard()
  if len(m)>0 and m!=lastm:
    print('2-touch y= '+str(m[1]))
  if k>0 and k!=lastk:
    print('key= '+str(int(log2(k))))
  lastm=m
  lastk=k
#end
The snippet prints the y-coord of the mouse pointer for a two-point touch, or the key code for a clicked calculator key and can be exited by pressing 'On'. Both mouse() and keyboard() don't seem to accept any parameters.
As noted in one of your previous posts, I haven't had any luck making a Python script file work (using the More>Files>New Program feature of the Editor).
Thanks for your invaluable contributions to the knowledge base. Your posted have been very helpful in trying to figure things out.
Jim
05-15-2021, 11:05 PM (This post was last modified: 05-16-2021 10:19 AM by Guenter Schink.)
(05-15-2021 01:04 AM)jkor Wrote:  I seem to have some success with the following snippet in PPL:
Jim
Thanks for your comment, and the code snipped, that helped a lot. Now I have a routine for mouse, at least on the virtual Prime, that seems to work reliably and easy to use. Checking out on the real Prime will follow. For now I call it a day, although I should call it a night at 1 hour past midnight here.
# So far only tested on the Virtual.
# Left mouse button returns first tuple
# Right mouse button returns second tuple
# initiate Maus as 1 tuple of 2 tuples
# and wait for a mouse event
# Maus is the German word for mouse :-)
Maus=((),())
while Maus==((),()):
  Maus=mouse()
# clear terminal Window as it fits, guess that's what you were looking for
eval("PRINT")
#split Maus into two tuples Maus1 and Maus2
# in Python it's easy this way
(Maus1),(Maus2)=Maus
#let's see what we got
print("Maus1:",Maus1,"Maus2:",Maus2)
#before doing something with first tuple,
#check  it's not empty
if Maus1>():
 (Maus1x,Maus1y)=Maus1
 print("Maus1x:",Maus1x,"Maus1y:",Maus1y)
#before doing something with second tuple,
if Maus2>():
  (Maus2x,Maus2y)=Maus2
  print("Maus2x:",Maus2x,"Maus2y:",Maus2y)
#end
EXPORT test7(a)
BEGIN
  PYTHON(name1, a);
END;
We'll continue to play with Python, no?
Günter
05-16-2021, 12:06 AM
Yes we definitely should continue. Like you, I am relatively new to Python, picking it up about a week ago. So, I see this as a golden learning opportunity, through actually trying to make things work.
I can't wait for the stable release, having many PPL programs that I am looking forward to revamping. Playing with the Prime has become an somewhat of an obsession, currently Smile. Of particular interest is coming up with generic framework for a GUI (cascading menus, dialog boxes and the like).
Again, thank you for the inspiration provided, and many thanks to the HP Prime team for a compelling product that ensures I don't get too much (enough) sleep.
Until the next hurtle, very best,
Jim
05-16-2021, 10:17 AM
Another trap:
in your snipped:
Quote: print('key= '+str(int(log2(k))))
doesn't always return the correct key code due to the binary nature of floats. This can be avoided by replacing <int> by <round>. In this case <round> even doesn't need a second argument. For positive numbers it works like <ceil> from the math module.
Quote: print('key= '+str(round(log2(k))))
Things like this could drive you crazy.
Günter
