RACK42 - A Spreadsheet Application for the DM42
09-02-2022, 01:33 PM
Hi!
I proudly present RACK42 - a small and powerful RPN spreadsheet application for the DM42 hardware. For more information have a look at https://github.com/zooxo/rack42 or see a short video at https://youtu.be/_lt0Zoqh0og Thanks in advance for any comment, suggestion or bug to make RACK42 faster, more versatile, stable and intuitive. Particularly I'm planning to expand the mathematical power of RACK42 (ie conditions, probabilities, hyperbolics, logic, base) and improve the handling (ie copying cell ranges, fixed cell references, more graphic charts) - so I'm curious which features are needed most to build in. Regards deetee |
09-02-2022, 07:15 PM
(This post was last modified: 09-02-2022 07:22 PM by Werner.)
RE: RACK42 - A Spreadsheet Application for the DM42
.. and proud you may be, this looks amazing!
Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE |
09-03-2022, 12:36 AM
Looks fun.
I see that rows are 15 and columns 6. How did you get to those dimensions ? |
09-03-2022, 12:43 PM
(09-03-2022 12:36 AM)Gene Wrote: I see that rows are 15 and columns 6. How did you get to those dimensions ? To display a number with 'sufficient' precision (what is sufficient?) you need 8 or 9 digits. With an easy 'readable' (what is readable?) font you can display on the screen 3 numbers (cells) in a line. The central part of the display (screen less status line less edit line less f-key line) allows 5 rows with this readable font. And finally - as rack42 demands to be small and clear - the number of rows should be a low multiple of 3|5. So I tried the first version of rack42 with 6|15. Regards deetee |
12-06-2022, 06:08 AM
Hi!
I proudly present version 2 of RACK42 - the spreadsheet application (and more) for the DM42 hardware. What started as an "experiment" became my favor DM42-application (even if there is IV42). For more information have a look at https://github.com/zooxo/rack42 or see a short video at https://youtu.be/5BZ6oYsfi6w What's new:
Thanks in advance for any comment, suggestion or bug to make RACK42 more versatile, stable and intuitive. Have fun! Regards deetee |
