RPN and decomposing list to stack
08-03-2014, 03:56 PM
In RPN, one can combine stacks into a list. Is it possible to decompose a list back into stack?
08-07-2014, 01:54 PM
RE: RPN and decomposing list to stack
On the Prime you can return a list but not decompose it. There is no way to return more than a single object to the stack.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
08-08-2014, 04:22 AM
Thanks. This is probably a naive question, but can't the list be decomposed sequentially somehow then, or the program can only return one object?
I don't even know how to get an element from a list by hand - SUB was the closest command I could find and it returns single-element list (how to get an element from it, I don't know).
08-08-2014, 02:24 PM
You get the element by direct access (e.g., L1(1) returns the first element of L1.)
This should be explained in the manual under "Lists", but maybe it isn't.
08-09-2014, 10:59 AM
Thanks, Helge!
How would it work with a {list} on stack - would it mean that I have to save it in a global variable first (e.g. L1) to be able to access elements, or somehow decompose the list?
Cheers!
08-09-2014, 02:59 PM
No, in CAS, you can do {1,2,3,4}(3) to retrieve the 3rd element. But in Home, that doesn't work, because of implied multiplication, so there, yes, save it first and then do name().
User(s) browsing this thread:
