Emulator Progs and Power Consumption
08-19-2014, 01:38 PM
Hello all.
I'm a new member here although I've been following this forum for some while. This is my first post, so... greetings from Nova Scotia, Canada.
I've seen several predictions of the impending demise of "hardware" pocket calculators in favour of calculator-like application programs on smartphones.
I use both extensively and I've noticed that extended use of a smartphone for computation seems to cause the device to consume battery power and generate heat at a prodigious rate. In my experience, an hour or so of hard use causes the device to get hot enough to cause worry about the longevity of the circuitry.
For the time being, I'll hang on to my 10b and 35s Wink
WBG
08-19-2014, 02:42 PM
RE: Emulator Progs and Power Consumption
Depends a lot on the emulator, really. If it's able to idle the device's CPU when the emulated system doesn't have work to do, it shouldn't be too hard on the phone's battery. Now, if the emulator isn't able to do that, and it pegs your phone's CPU emulating idle loops at full speed, you're going to feel it.
And if it's an entire reimplementation like Free42, it should be very gentle on the battery.
08-20-2014, 01:33 PM
(08-19-2014 01:38 PM)W.B.Grant Wrote:  In my experience, an hour or so of hard use causes the device to get hot enough to cause worry about the longevity of the circuitry.
Don't. It starts to be a problem if you don't want to touch your phone anymore, maybe even later.
Welcome to this friendly forum!
08-22-2014, 01:42 PM
Thanks, Thomas Smile
Dave: Thanks for the tip about Free42; that looks like a great proggie.
08-22-2014, 02:07 PM
(08-22-2014 01:42 PM)W.B.Grant Wrote:  Dave: Thanks for the tip about Free42; that looks like a great proggie.
It definitely is! It's a from-scratch reimplementation rather than emulation, so it's blazing fast compared to the original hardware on just about any platform (even my old Palm).
08-22-2014, 02:44 PM
+1. The best smartphone application for calculating I know.
d:-)
08-22-2014, 10:56 PM
(08-22-2014 02:44 PM)walter b Wrote:  +1. The best smartphone application for calculating I know.
I like it so much that it's on every page of my iPod Touch:
[Image: iPodTouch.png]
<0|ɸ|0>
-Joe-
08-22-2014, 11:07 PM (This post was last modified: 08-22-2014 11:07 PM by Massimo Gnerucci.)
Oh well, this is Android... Big Grin
