[SOLVED] Newest fw INPUT syntax?
12-19-2016, 12:18 AM (This post was last modified: 12-19-2016 06:05 PM by chromos.)
1) Please, do you anybody know which is new syntax for INPUT command? I need store expressions, something like A+B or G-K/L etc. It worked in previous fw, but I am unable understand current syntax - I tried "everything", but everytime I get orange exclamation mark and programm is still on INPUT screen.
2) Is there alternative to lname command in Home?
Thank you very much.
Prime G2, 15C CE
12-19-2016, 02:24 AM
RE: Newest fw INPUT syntax?
(12-19-2016 12:18 AM)chromos Wrote:  1) Please, do you anybody know which is new syntax for INPUT command? I need store expressions, something like A+B or G-K/L etc. It worked in previous fw, but I am unable understand current syntax - I tried "everything", but everytime I get orange exclamation mark and programm is still on INPUT screen.
It helps to share a snippet of your code so we can help debug.
Graph 3D | QPI | SolveSys
12-19-2016, 02:58 AM
OK, this worked until fw update to latest release:
PHP Code:
INPUT(Temp,[2],"Expression","Variables must be in UPPERCASE! (e.g. A+B-4)");
I tried many variations of [2] - with different parentheses, even without them, at different places - with no success.
That line code is line # 293 from Geo Coords Solver:
http://www.hpmuseum.org/forum/thread-536...l#pid48133
Prime G2, 15C CE
12-19-2016, 11:18 AM (This post was last modified: 12-19-2016 11:25 AM by DrD.)
Did you create local variable Temp, first?
Would this adaptation be of any use to you?
EXPORT test()
BEGIN
  LOCAL Temp;
//  INPUT(Temp,[2],"Expression","Variables must be in UPPERCASE! (e.g. A+B-4)");
  INPUT(
         { {Temp, [2], {25,74,3} } },
         "Resolve Expression",
         "Expression",
         "Variables must be in UPPERCASE! (e.g. A+B-4)",
  RETURN Temp;
END;
-Dale-
12-19-2016, 04:56 PM
It seems to work fine for me here (provided Temp has been defined as pointed out).
Quote:2) Is there alternative to lname command in Home?
LNAME is also a home command. Takes an expression 'X^2+Y' for example, and returns { X, Y }. Does that do what you want?
If none of the answers given seem to help you, please post some snippets so we can see and help more.
TW
12-19-2016, 06:00 PM
Your example works, thank you very much, Dale.
Prime G2, 15C CE
12-19-2016, 06:04 PM (This post was last modified: 12-19-2016 06:07 PM by chromos.)
Thank you Tim for your advice about LNAME command in Home. I was almost sure I saw it somewhere in the past, but I didn't remember single quotes.
Both my questions are solved now.
Prime G2, 15C CE
User(s) browsing this thread:
