Can't make format() work
02-19-2017, 10:17 PM
In examples I've seen
format(9.3456,"s3")
should show 9.35 in algebraic mode but All I get is syntax error. Since format is in lower case, I also tried
CAS.format(9.3456,"s3")
with the same result. How do you use the format function? Also, how do I set fixed decimal mode from an HPPL program?
Tom L
Tom L
Cui bono?
02-19-2017, 11:57 PM
RE: Can't make format() work
It needs CAS(format(9.3456,"s3")), not CAS.format.
Just checked and its still OK on the new release on Android.
http://www.hpmuseum.org/forum/thread-647...ght=format
Stephen Lewkowicz (G1CMZ)
02-20-2017, 02:11 AM
(02-19-2017 11:57 PM)StephenG1CMZ Wrote:  It needs CAS(format(9.3456,"s3")), not CAS.format.
Boy am I getting old! I even replied to that thread! :0
Tom L
Tom L
Cui bono?
