hp 50g firmware update procedure note
04-12-2017, 08:57 PM (This post was last modified: 04-13-2017 06:53 AM by pier4r.)
I know, the topic is old, still I did find a bit of confusion while installing the newRPL firmware.
The notes contained in the rom 2.15 to flash the firmware with the USB say:
- install the USB connectivit kit provided from hp (or hpcalc.org, I say)
- in the case install the usb drivers (again, hpcalc.org if needed)
- then select USB calculator in the connectivity kit program
- then follow the instruction on the screen.
The instruction on the screen mentioned a reset with a paperclip. I was a bit skeptical and I checked online, finding this link: https://www.educalc.net/2137081.page
(google search string "50g install new firmware usb")
Once again:
Quote:On the calculator side:
Off the calculator and the hold + - key and then using a pin to push the reset slot (back).
Press 1 to select "Update Code".
Press 1 to select "USB"
The screen will display "BEGIN UPDATE" and it will show the progress till the entire sequence has completed.
Well I still was skeptical because the procedure with the SD card install was real quick. In particular:
[Image: maDplnA.png]
I followed the procedure without using the SD card, I just got to the UPDATE CODE part (so no clip needed to reset the calculator). Then I prepared the connectivity kit and the USB cable.
Then I selected USB instead of CARD, and it worked.
[Image: vWZJIZ3l.jpg]
Since I was not able to find this procedure on this forum, I though was useful to share to simplify the life of other users.
The procedure with a clip (but again, no SD card needed) was needed to move back from the newRPL firmware to the 2.15 firmware.
