Question on INPUT
09-13-2017, 05:33 PM
Question on INPUT
Bonjour
Dans un INPUT, j'ai 3 cases à cocher : choix1 choix2 choix3 Je souhaite que choix1 annule choix2 et choix 3, que choix2 ou choix3 annulent choix1 mais que choix2 et choix3 soit possible. Est-ce possible ? Hello In an INPUT, I have 3 checkboxes: choices1 choices2 choices3 I wish that choice1 cancels choice2 and choice 3, that choice2 or choice3 cancel choice1 but that choice2 and choice3 is possible. Is it feasible? Sorry for my english |
09-13-2017, 06:38 PM
(This post was last modified: 09-13-2017 06:42 PM by chromos.)
RE: Question on INPUT
(09-13-2017 05:33 PM)Tyann Wrote: Hello I don't know if this is possible in one INPUT, but it looks to me your logic is somewhat redundant, ie. checkbox 1 is unnecessary: 1) checkbox 2 and/or 3 are checked => treat it as checkbox 1 is unchecked; 2) neither checkbox 2 nor checkbox 3 are checked => treat it as checkbox 1 is checked. Prime, 15C CE |
09-14-2017, 04:37 AM
Bonjour
Logiquement vous avez raison. Mais si la case à cocher 1 n'est pas créer l'utilisateur n'a pas l'information. La solution que j'ai trouvé pour le moment est de mettre une quatrième case qui regroupe choix2 et choix 3 avec la valeur [4] sur la première case à cocher. Merci pour votre réponse qui cependant mérite reflexion. Hello Logically you are right. But if checkbox 1 is not create the user does not have the information. The solution I found at the moment is to put a fourth box that combines choice2 and choice3 with the value [4] on the first checkbox. Thank you for your answer which nevertheless merits reflection. Sorry for my english |
09-14-2017, 04:57 AM
No, sorry, this is not possible through the automatic system. You should think about it as a 1 out of 5 choise system and use a choose. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
09-14-2017, 04:08 PM
(09-14-2017 04:57 AM)cyrille de brébisson Wrote: Hello, Merci Cyrille pour la confirmation. Thank you Cyrille for the confirmation. Sorry for my english |
