Solve for X and Y
01-25-2018, 09:09 AM
Solve for X and Y
hello
how can i solve this two equations with Hp prime ? Need to solve for X and For Y . see please attachment. Thank you |
01-25-2018, 09:26 AM
RE: Solve for X and Y
You can use the app Solve, then (in Symb) write the equations in E1 and E2; in Num give some guess tries for X and Y and press Solve:
X=9, Y=-4 Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-25-2018, 10:20 AM
Not to forget the Linear Solver App, you simply enter your 6 numbers and push Solve.
Arno |
01-25-2018, 10:48 AM
(01-25-2018 10:20 AM)Arno K Wrote: Not to forget the Linear Solver App, you simply enter your 6 numbers and push Solve. Right, yes! ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-25-2018, 10:58 AM
You could use a graphical approach, using the Advanced Graphing App. The two solutions show up nicely at the intersections of the two expressions:
Points (X,Y) = (4,9) and (9,-4) [attachment=5592] -Dale- |
01-25-2018, 11:12 AM
RE: Solve for X and Y | |||
01-25-2018, 11:25 AM
(01-25-2018 11:12 AM)Arno K Wrote: No, I was wrong, did not enlarge that pic, so I did not see that the second equation is quadratic. and I was wrong two times, then, replying too soon ok, the second equation is not linear... ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-26-2018, 08:41 AM
solve({13*x+5*y=97,x^2+y^2=97},{x,y})
