PWRX 23 january version bug
01-28-2018, 10:52 AM
Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards.
01-28-2018, 05:28 PM
RE: PWRX 23 january version bug
(01-28-2018 10:52 AM)suhast Wrote:  Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards.
Thanks for posting. I was going to update my CL later today, but I will hold off until hearing about this, and possibly an update to PWRX if needed.
01-28-2018, 05:34 PM
Regards.
Maybe if someone could confirm this bug/contact Angel for a fix?
Is there any manual with the latest version fixes or changes?
Regards.
01-29-2018, 12:06 AM
(01-28-2018 05:34 PM)suhast Wrote:  Maybe if someone could confirm this bug/contact Angel for a fix?
Regards.
When Angel is free, he'll be checking here; probably within a day or two.
01-29-2018, 01:49 AM
The BAUD and TURBO menus dont work also, when I try using the commands in those menus it displays “no YFNX” although I have the yfnx installed
02-13-2018, 01:38 PM
Both issues have been fixed and are available on the CL library as of February 2018.
"To live or die by your own sword one must first learn to wield it apply."
