INPUT command [allowed_types_matrix]
02-16-2018, 12:57 AM
Hi Friends,
I need to create an INPUT with ONE field that accept REALS (0 type) and too FUNCTIONS (8 type) so I used [ 0 , 8 ] as [allowed_types_matrix] ... this field only accept REALS (0 type) AND WITH 'X+5' GIVES "Error : Invalid input" I created the following program for example (with 2 fields to not leave the form and test many times): PHP Code: EXPORT INPUTTEST Please Your help with any suggestion, thanks. Best regards!! josephec |
02-16-2018, 01:34 AM
RE: INPUT command [allowed_types_matrix]
Input is failing!
With {{fx,[8]} it should be enough, but currently it seems not to accept data if it does not contain any variable, clearly this is a bug. Viga C | TD | FB |
02-16-2018, 01:54 AM
(02-16-2018 01:34 AM)Carlos295pz Wrote: Input is failing! Thanks Carlos.. I will use only type 8. And if the user needs to enter a REAL 5 would use '5+0' trick. Have a great day. Josephec |
