using solve app from a program
02-17-2018, 03:05 AM
Hi, this the code i've been struggling with (it's pretty basic)
EXPORT TRX_3()
local a;
STARTAPP(solve);
a:=solve.solve(E1); //here is the problem
print();
print(a);
//variations i tried:
//a:=solve(E1,{X});
//a:=SOLVE(E1,{X});
//a:=Solve(E1,{X});
//a:=Solve.SOLVE(E1,{X});
//a:=solve.SOLVE(E1,{X});
//a:=SOLVE.solve(E1,{X});
//a:=solve(E1);
//a:=SOLVE(E1);
//a:=Solve(E1);
//a:=Solve.SOLVE(E1);
//a:=solve.SOLVE(E1);
//a:=SOLVE.solve(E1);
the content inside E1 is the following: 0.5=(2*E^-3*X)/(1+1*E^-3*X)
and the solution that i get directly from the app is x:333.33
02-17-2018, 03:18 AM
RE: using solve app from a program
I didn't try, but are you sure STARTAPP(solve); is right?
PHP Code:
STARTAPP("Solve");
Geocaching Coords Solver, Number of triangles Puzzle
02-17-2018, 01:25 PM
In Home, Solve.SOLVE(E1,X) gives the right answer 333.333.
Also, the next program returns the correct answer:
EXPORT TRX_3()
  LOCAL a;
  a:=Solve.SOLVE(E1,X);
  print(a);
02-18-2018, 03:35 PM
Thx a lot, actually both observation were accurate, the final code in case someone else need it is the following:
EXPORT using_solve_from_program()
LOCAL a;
//get the equation you want
//to solve inside the slot E1
STARTAPP("Solve");
STARTVIEW(0);
msgbox("make sure the equation you want
to solve is inside the E1 slot");
print();
print(a);
User(s) browsing this thread:
