New Version: 2018.02.12 1.4.1.13441
02-21-2018, 08:12 PM
New versions are available on the update archive. I highly recommend just running check for update in your emulator/connkit to get the files. If your network blocks direct connection however, the direct links can be found below at "ftp.hp.com/pub/calculators/Prime/".
The iOS/Android/Winstore versions will be downloaded through your normal phone update mechanism as they are approved by the various stores. They are still pending at this time.
HP Prime Connectivity Kit Installer - Windows
HP Prime Virtual Calculator Installer - Windows
HP Prime Connectivity Kit DMG - macOS
HP Prime Virtual Calculator DMG - macOS
HP Prime Calculator Firmware
This is essentially a re-release of the last version with a few corrections to some regressions. The details of fixes and new features can be found in the original thread. See that for full details.
Quote:HP Prime – Release Notes
Date Released: 2018/02/12
Internal Versions
Firmware Version: 2018 02 12 (13441)
Virtual Calculator Version: 2018 02 12 (13441)
Connectivity Kit: 2018 02 12 (13441)
Description
Primary focus in this release is to correct some regressions introduced in last version. Think of this release as a re-release of the previous version 2018 02 12 (13333).
Resolved issues and changes excluding CAS
1. Resolved issue with DIMGROB command causing issues with existing programs
2. Resolved issue with empty list in geometry
3. Resolved issue with some unicode characters
4. Resolved issue with EXPR and nested list calling
5. Resolved issues with a few spelling or syntax issues in the on-calc help.
Resolved issues and changes in CAS
1. Resolved issue with | in the CAS creating permanent variable
TW
02-21-2018, 09:17 PM
RE: New Version: 2018.02.12 1.4.1.13441
Got it. Easy peasy!
When I launched the Connectivity Kit, it immediately asked me if I wanted to perform the update to this new version. I backed up and went ahead, and everything went perfectly well.
Thanks a million Tim!
smp
02-21-2018, 09:20 PM
Ohhhh EXPR!!
Viga C | TD | FB
02-21-2018, 09:26 PM
(02-21-2018 09:20 PM)Carlos295pz Wrote:  Ohhhh EXPR!!
Yup, thanks for that.
TW
02-21-2018, 10:19 PM
Everything updated perfectly on my three Primes (HW A, HW C old keyboard, HW C new keyboard). Thanks, Tim!
Tom L
Cui bono?
02-21-2018, 10:21 PM
Blush
Viga C | TD | FB
02-21-2018, 10:29 PM
Now if you will all quit finding problems I can get on to interesting things... Tongue
TW
02-21-2018, 10:32 PM
Thank You very much for Ē, Ģ, ģ. Smile
02-21-2018, 10:55 PM
(02-21-2018 10:29 PM)Tim Wessman Wrote:  Now if you will all quit finding problems I can get on to interesting things... Tongue
Like adding pointers, datatype specifiers (like INT, REAL, STRING) and user-defined records (like structures in C) to HPPL? Please, please?
One can dream, can't one?
Tom L
Cui bono?
Install was easy, no problems, but I had to download the VC by hand.
Checking my keyboard problem with "Alt Gr" to input one of {[]} I found another issue, I typed AltGr + [ and the matrix brackets showed as wished, cursor in the matrix, on pos 1. So I tried fff as data for that element, that produced fff and not FFF, so the shift key was switched off, ok. Then I moved the cursor right with the arrow key on my keyboard to fill the next position and the cursor jumped behind the closing bracket, attempts to put the cursor back in the matrix using arrow-keys failed, the cursor only jumped between: before [ and behind ] . Mouse or finger (its a PC with touchscreen) can be used to edit the second element. After "Enter" and then copy the matrix back from history to the editline the cursor key behaved the same. On the HW Prime that works as expected.
Arno
02-21-2018, 10:57 PM
Ok, see my post above. ;-)
Arno
02-22-2018, 03:24 AM
Thanks Tim,
Smooth updates (physical and virtual) so far.
Alex
02-22-2018, 04:44 AM
Any timeline for updating the iOS HP Prime Pro app to include the 13441 fixes?
Tom L
Cui bono?
02-22-2018, 05:14 AM
They are waiting on apple/google...
TW
02-22-2018, 05:56 AM
Tim Wessman, thank you, but I must say that his kit is horrible, with all the sincerity I think the hp prime team is incapable.
I hope some day you can make the kit very good, because until now, the block of notes is better.
02-22-2018, 07:13 AM
is a very good and witty phrase xD, the members' trust is nice
Viga C | TD | FB
02-22-2018, 08:15 AM
Aún deseo que el Kit pueda manipular la inserción y retiro de archivos, como si de Windows Explorer se tratara, tengo muchas ganas de ampliar el conocimiento de uso de archivos con Aplicaciones porque ese es hasta ahora el punto más fuerte que tiene la calculadora para la persistencia de datos.
Por otro lado adiciona una funcionalidad más a las aplicaciones de terceros al poder dar verstalidad al intercambiar archivos creados sus Apps instaladas, retirar toda la App y el fallo tras cargar varios archivos aún no promociona esa funcionalidad.
I still want the Kit to be able to manipulate the insertion and output of files, as if it were Windows Explorer, I really want to expand the knowledge of use of files with Applications because that is until now the strongest point the calculator has for the persistence of data.
On the other hand adds a functionality to third-party applications to be able to give verstalidad when exchanging files created with yours installed Apps, remove the entire App and the failure after loading several files has not yet promoted that functionality.
Viga C | TD | FB
02-22-2018, 09:38 AM (This post was last modified: 02-22-2018 09:39 AM by Arno K.)
I would like to see it work as an IDE, edit, debug and send programs around, clearly with all help included, like on the calculators.
Arno
02-22-2018, 10:45 AM
:-P
eheheh...
Here all was ok: Windows, Mac OS X, Prime A and Prime C, thank you!
Salvo
02-22-2018, 10:49 AM
To Arno's list, additional features to enhance the CK user experience such as:
• font size/color,
• search/replace,
• command autofill,
• context sensitive help, (like using F1 or hover over a command to show help description),
• debug improvements
rise to the top of my wish list!
-Dale-
