Arduino Board as HP-IL device?
07-22-2019, 03:24 PM
Post: #41
RE: Arduino Board as HP-IL device?
(07-22-2019 02:29 PM)Artur - Brasil Wrote: Hi, guys! Portable mass storage has already been done. https://www.hpmuseum.org/forum/thread-10...l#pid18204 |
07-23-2019, 12:55 PM
Post: #42
Quote:Portable mass storage has already been done. Yes, I know, but or they are too expensive or they need another hardware for support them. ARTUR MARIO JUNIOR BRAZIL |
08-06-2020, 11:04 AM
Post: #43
(09-02-2014 05:27 PM)charger73 Wrote: Hi all Revisiting this thread after a long time: what is the status of this solution? Was there any additional development and are the sources and documents up-to-date? I was considering to build a simple mass storage solution for my HP Portable Plus in case my 9114 starts to fail. I would prefer combining the PIL-Box part and the Arduino firmware into a single micro-controller (Arduino PIC, STM, ESP). Martin |
08-22-2020, 11:13 AM
Post: #44
(08-06-2020 11:04 AM)Martin Hepperle Wrote:(09-02-2014 05:27 PM)charger73 Wrote: Hi all Hi Martin, I just dropped a mail to Tobie, maybe he has missed your question ... Best regards, Jürgen |
03-13-2021, 09:20 PM
Post: #45
Hello Tobie,
I am building two Arduino-IL-Drive units. I have received the Arduino boards and waiting for the PIL-Box to become available again to complete this project. From the source code analysis that I did, it is currently compatible with PIL-Box version 1.6 firmware. (9.6Kbps & 115.2Kbps) I did some tests with Serial1 port and I was able to successfully transmit at 230Kbps. This means that with minor modification of the Arduino source code I should be able to use PIL-Box v2.1 firmware. What is the product number of the box you used ? Regards, Sylvain |
03-14-2021, 07:29 AM
Post: #46
Hi Sylvain
My last Arduino drive I build, was with the PIL Version 1.5. So, I have no experience with the Version 2.x Since about 6 years, there was no development on this project from my site Best Regards Tobie |
03-15-2021, 12:53 PM
Post: #47
Hello Sylvain,
please look at the pictures in my thread "Arduino IL Drive Sim read good write bad" https://www.hpmuseum.org/forum/thread-14041.html I use PILBox 2.1. Jean-Francois send it to me in october 2019 with this information: "Your PIL-IO board kit with PIL-Box MCU has been shipped yesterday. Assemble it as a standard PIL-IO board. Then, since it uses the PIL-Box firmware, a jumper (provided) must be installed on JP2 to set the com speed to 115kbps." Regards Klaus |
03-15-2021, 01:38 PM
Post: #48
Hello Klaus,
I am at work right now (EDT GMT-4h). I did a fast diagonal read and it looks very interesting. Thank you very much for the information. Regards, Sylvain |
04-11-2022, 07:02 PM
Post: #49
(04-02-2014 08:49 PM)Jurgen Keller Wrote: I don't know much about electronics, however, as you can implement nearly anything with an Arduino board I'm wondering if you can also make one acting as a HP-IL device. I see two basic variants:So far, I am using a raspberry PI4 (not arduino; however, small size). On the ToDo list is now to make it headless (prio C for me); however, a terminal output is good. HP71 & Multimod, HP41CV/CX & Nov64d, PILBOX, HP-IL-PRINTER 82162A, RS232 HP-IL interface, Debian11 64bits-PC w/ pyILPER, V41R9F & EMU71 |
