3d-printing a thinner HP41CX back cover
02-26-2018, 04:52 PM
Hi there,
I enjoy my 41cx, but sometimes wish it was a little bit thinner. I think there are a couple of people on the forum who are skilled at 3d printed parts. So is it possible to redesign the back cover and make 41cx a little bit thinner?
thanks,
02-26-2018, 05:57 PM
RE: 3d-printing a thinner HP41CX back cover
(02-26-2018 04:52 PM)atilla457 Wrote:  Hi there,
While feasible to make the lower portion a small amount thinner (perhaps 1-2mm as it sits just above the CPU board), the thickness of the upper portion cannot be reduced because of the ports for the 4 x ROM/RAM modules. And since that cannot be reduced, very little would be gained by reducing just the lower section. So a lot of work for very little benefit IMHO.
02-26-2018, 07:02 PM
(02-26-2018 05:57 PM)rprosperi Wrote:  the thickness of the upper portion cannot be reduced because of the ports for the 4 x ROM/RAM modules.
Unless you make it a real half-nut with 2 module ports Wink
02-26-2018, 07:29 PM
I am so eternally grateful they did not implement that plan.
Håkan
02-27-2018, 04:58 AM
(02-26-2018 07:02 PM)Didier Lachieze Wrote:  Unless you make it a real half-nut with 2 module ports Wink
No! No ports and a Lipo battery. We could get rid of the mid-piece bezel and bottom on a half nut. Direct power onto the main board and get rid of the battery flex circuit...
I just checked my boneyard and have about a half-dozen full nuts in various states of repair but no half nuts.
Shopping we go!
02-27-2018, 07:48 AM
(02-27-2018 04:58 AM)Nate Martin Wrote:  I just checked my boneyard and have about a half-dozen full nuts in various states of repair but no half nuts.
Isn't a half-dozen full nuts = a dozen half nuts?
Greetings,
    Massimo
02-27-2018, 07:58 AM
Smile
Sigh. That's just nuts...
(Post 183)
Regards, BrickViking
HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a)
02-27-2018, 08:04 AM
(02-27-2018 04:58 AM)Nate Martin Wrote:  No! No ports and a Lipo battery. We could get rid of the mid-piece bezel and bottom on a half nut. Direct power onto the main board and get rid of the battery flex circuit...
A null nut then.
Pauli
02-27-2018, 11:01 AM
Smile
And what do you store them in, a nut case? Tongue
02-27-2018, 11:42 AM
(02-27-2018 11:01 AM)grsbanks Wrote:
(02-27-2018 07:48 AM)Massimo Gnerucci Wrote:  Isn't a half-dozen full nuts = a dozen half nuts?
Smile
Ok, I'm going nuts.
Greetings,
    Massimo
02-27-2018, 01:19 PM
No ports? Then you have a DM-41!
Tom L
Cui bono?
User(s) browsing this thread:
