probability plot - weibull
03-09-2018, 08:26 PM
I own my HP Prime for some day and I am fascinated about the possibilities.
I have now one question. I would like to calculate failure probabilities with "Weibull probability plots" based on measured data.
So my question is, is there any probability to generate a Weibull probability plot on a HP Prime?
I have seen the weibull and weibull_cdf function but I don't know what the parameters (k,n,t,x,x2) are and how I could calculate these parameters with the HP Prime based on my measured data.
Thank you. & Best regards,
Marcus
03-10-2018, 07:11 AM
RE: probability plot - weibull
The syntax is :
weibull_cdf(Real(k),Real(lambda),[Real(theta)],Real(x1),[Real(x2)])
Cf. https://en.wikipedia.org/wiki/Weibull_distribution for parameter definitions, theta is an additional optionnal parameter, a shift in x.
03-10-2018, 01:07 PM
Hey Parisse,
thank you for you answer regarding weibull_cdf.
I think this function is useful when I know the parameters of my weibull distribution. My problem is, that I have measured data and would like to build/fit a weibull function based on this data.
Has anyone an idea how to realize this with my HP Prime?
Best regards,
Marcus
03-10-2018, 11:44 PM (This post was last modified: 03-10-2018 11:50 PM by Marcus_W.)
Hey,
I think I found a solution, based on this:
http://www.real-statistics.com/distribut...egression/
I am not so good in coding, but maybe there is someone how can use this:
LOCAL len :=0;
LOCAL n :=0;
LOCAL param := 0;
LOCAL beta := 0;
LOCAL lambda := 0;
LOCAL value := 0;
EXPORT weibull_ifitr(data,percent)
C1:=data;
len:=length(C1);
C2:=sort(C1);
C3:=ln(C2);
FOR n FROM 1 TO len DO
C4(n):=(n-0.5)/len;
C5:=ln(-ln(1-C4));
param:=linear_regression(C3,C5);
beta:=param(1);
lambda:=e^(-param(2)/param(1));
value:=weibull_icdf(beta,lambda,percent);
RETURN value;
Comments are welcome.
bye,
Marcus
