Delta Wye Converter
03-28-2018, 10:26 PM
Delta Wye Converter
DeltaWye converter
The opening screen will give you:
1- DeltaWye (go directly to the solve section.)
2-Set_Format_Digit (Select # of digits and Format) Enter. Takes you to 1-.
The next screen will present to you the position of the Resistances or Impedances in the network.
Press Enter to go on to the Data entry phase where the top boxes represent the Wye net work, and the bottom boxes represent the Delta network.
The answer screen will give the result in both Rectangular and Polar version.
BM
Attached File(s)
.hpprgm  DeltaWye.hpprgm (Size: 8.38 KB / Downloads: 21)
