i41CX+ feature request (or if already there, request to end my ignorance) :-)
03-30-2018, 07:08 PM
I would like the ability to print a program from memory (or rom) directly to a .txt file that can be emailed within the i41CX+ environment.
I wanted to get a listing of the QUEUE program from the Test Stats 1B rom (Angel's work) and was scratching my head.
Any suggestions ?
03-30-2018, 07:56 PM
RE: i41CX+ feature request (or if already there, request to end my ignorance) :-)
I don't know about i41CX+... But I have i41CX, with the printer add-on, and when I send output to the emulated printer, I can then email it from within the app. I don't know if there is a limit to the number of lines it will buffer, but I just tried this with the PRPLOT program from the printer ROM, which is 341 lines, and that worked fine.
03-30-2018, 08:33 PM
And there you go. Thanks Thomas. As Homer Simpson might say "Doh!"
Another question. The app does seem to limit the size of the printer roll. I was asked 3 times to save the roll for the QUEUE program (which is 960+ lines long). That created 3/4 images in the phone camera roll.
It also made it tough / impossible to email the TEXT of the program since the printer only emailed the **last** portion of the printer paper roll.
03-30-2018, 08:44 PM
If, instead of saving the print-out when prompted, you hit "dismiss", it will happily keep adding to the existing one. I just verified that I can print PRPLOT three times and then email the print-out, which is well over 1000 lines at that point. Generating the email took a couple of seconds, but the output is all there, in text and image. (You can turn off emailing the image, which would probably speed things up a bit.)
03-30-2018, 08:55 PM
Excellent. Worked as desired and advertised. Many thanks.
It turned out to be a request to end my ignorance. :-)
