(HP-67/97) A simple tennis game
04-23-2018, 11:37 AM
I just read some older posts in the HP41 Software Library and I found Namir's "Cyber Tennis Game for HP-41C". So I thought I could do something similar for the good old HP67/97:
001  LBL E
002  ABS
003  FRAC
004  STO 0
005  LBL A
006  CLX
007  STO 1
008  STO 2
009  GTO 1
010  LBL B
011  RCL 0
012  Pi
013  +
014  x^2
015  FRAC
016  STO 0
017  2
018  *
019  STO I
020  ISZ
021  ISZ(i)
022  9
023  RCL(i)
024  X<=Y?
025  GTO 1
026  RCL 1
027  RCL 2
028  -
029  ABS
030  2
031  X>Y?
032  GTO 1
033  GSB 1
034  PAUSE
035  PAUSE
036  RTN
037  GTO A
038  LBL 1
039  FIX
040  DSP 2
041  RCL 1
042  RCL 2
043  EEX
044  2
045  /
046  +
047  RTN
048  GTO B
Usage:
Enter a seed (between 0 and 1) for the random number generator and press [E].
This starts a new match.
A new match can also be started by pressing [A]. This does not change the random seed.
Press [B] to play the next point.
The score is displayed as yy.cc where yy is your score and cc the calculator's.
Note: After having started with [E] or [A] you may also simply press [R/S] to play the next point.
The match is won as soon as one of the players reaches 10 points and his score is higher by at least two points. This can be modified by changing the numbers in line 022 (more than 9 points to win) and 030 (at least 2 points ahead required).
If you try a seed of 0,123 you will see a quite exciting match. ;-)
0,123 [E]      0.00
      [B]      0.01
      [B]      1.01
      [B]      1.02
      [B]      2.02
      [B]      2.03
      [B]      3.03
      [B]      3.04
      [B]      3.05
      [B]      3.06
      [B]      4.06
      [B]      4.07
      [B]      4.08   looks like you've lost
      [B]      4.09   matchpoint for calculator
      [B]      5.09
      [B]      6.09
      [B]      7.09
      [B]      8.09   you've almost caught up!
      [B]      9.09
      [B]     10.09   matchpoint for you
      [B]     10.10
      [B]     10.11   matchpoint for calculator
      [B]     11.11
      [B]     11.12   matchpoint for calculator
      [B]     12.12
      [B]     13.12   matchpoint for you
      [B]    "14.12"
             "14.12"
              14.12   you won -- what a match!
The program has less than 50 lines, so a version for a lower end calculator – maybe the 12C – should not be too difficult. ;-)
Dieter
