Tantal Cap - strange color code?
05-01-2018, 08:45 AM (This post was last modified: 05-01-2018 10:33 AM by AndiGer.)
There is a - I suppose - tantal capacitor inside my HP-97 main baord with strange color code that has to be replaced.
Orange head, pink - red - green lines. No colored dot but blue line to indicate anode I guess.
According to the service manual could be C1 (2.2 µF) as it's anode is attached to T1 inductor and cathode to 2 diodes - CR6 and CR7?
C3 located near ACT / PIK has the same strange color coding.
Not cleary visible in the lower part of the picture you can see yellow - purple (C6?) cap (orange marked head, brown or grey dot) and red - red - black dot (C4?) cap.
The board's layout isn't the one given in the service manual - all 5 ROM chips in a line. So the position of the other components is also different.
Anybody suggest a replacement? Is it 2.2 µF? Thank for your advice / experience.
Edit: added . in C1 2.2uF
05-01-2018, 10:27 AM
RE: Tantal Cap - strange color code?
(05-01-2018 08:45 AM)AndiGer Wrote:  There is a - I suppose - tantal capacitor inside my HP-97 main baord with strange color code that has to be replaced.
According to the service manual could be C1 (22 µF) as it's anode is attached to T1 inductor and cathode to 2 diodes - CR6 and CR7?
C1 is marked as 2.2uF in the manual I have and matches the position in the circuit as you described with (+) connected to the inductor.
cheers
Tony
