41c native user program hex dump
05-23-2018, 11:51 PM
(This post was last modified: 05-24-2018 12:04 AM by Craig Bladow.)
Does there exist a 41c program that will dump the bytecodes from another program in memory? Bonus points if the output is on an HP 41 compatible printer. I know I can go the IL->9114b->floppy->sneakers->PC to lifutils route or use an emulator but would like something native to the 41c.
Try CC41! |
05-24-2018, 12:37 AM
RE: 41c native user program hex dump
(05-23-2018 11:51 PM)Craig Bladow Wrote: Does there exist a 41c program that will dump the bytecodes from another program in memory? Bonus points if the output is on an HP 41 compatible printer. I know I can go the IL->9114b->floppy->sneakers->PC to lifutils route or use an emulator but would like something native to the 41c. Did you check the PPC ROM manual? I believe there is a program in there that does that (or function that could be used in a larger program), though I could be recalling a program from the PPC Journal; it's been (too) many years... --Bob Prosperi |
05-24-2018, 01:54 AM
Wickes' book on Synthetic programming has a program called "backtalk" that will translate data in the 14 byte X register into readable characters in the alpha register. I will check the PPC ROM manual and if the routine exists, hopefully there is a listing, or better yet, bar code.
Try CC41! |
05-24-2018, 02:05 AM
(05-24-2018 12:37 AM)rprosperi Wrote: Did you check the PPC ROM manual? I believe there is a program in there that does that (or function that could be used in a larger program), though I could be recalling a program from the PPC Journal; it's been (too) many years... Not in the PPC ROM manual... Finding it in the PPC Journal will take a little longer..... Try CC41! |
05-24-2018, 02:37 AM
(This post was last modified: 05-24-2018 02:40 AM by Gene.)
V10N4P29_HP-41C_Direct_Byte_Listing_of_Programs
Best I could find. Requires extra modules. |
05-24-2018, 03:08 AM
(05-24-2018 02:37 AM)Gene Wrote: V10N4P29_HP-41C_Direct_Byte_Listing_of_Programs Thanks Gene! Unfortunately I don't have any of those modules. Try CC41! |
05-24-2018, 03:17 AM
41CL is your friend. :-)
Say it. lol. |
05-24-2018, 03:24 AM
Try CC41! |
