[CAS] limit() question
05-25-2018, 10:27 AM
I encountered this limit example:
limit(ABS((x-2)^(n+1)/((n+1)^2*3^(n+1)) / ((x-2)^n/(n^2*3^n))),n,∞); ==> undef During a simplification process, (of the underlying expression), a result is obtained at this equivalent expression: limit(ABS((x-2)*n^2/((n+1)^2*3)),n,∞); ==> ABS(x-2)/3 Further simplification continues to return ABS(x-2)/3. Should the original (un-simplified) expression, also return this result, (instead of "undef")? -Dale- |
05-26-2018, 06:07 AM
RE: [CAS] limit() question
Yes, undef is expected, because limit does series expansion without simplifications (because simplify could return a much harder limit), and you can not do that for (x-2)^n without assumption on x (need to know the sign of ln(x-2)). If you run for example assume(x>3) the initial limit will be solved. Or if you run simplify, because it will remove the (x-2)^n.
05-26-2018, 08:19 AM
Thank you for your explanation, Parisse.
-Dale- |
