Programming solve function
06-04-2018, 05:07 PM
(This post was last modified: 09-17-2019 05:28 PM by Gene222.)
I am having trouble programming the SOLVE and fsolve functions, and I am not sure of what I am doing wrong. I can run solve on the HP Prime, but I can't programmatically solve the equation.
![]() EDIT 6/4/18 corrected error in code with the radius, but still can't get code to work. Code: EXPORT OldAAngleSetting,theta,radius,x,q,v; |
06-05-2018, 12:33 AM
RE: Programming solve function
The value returned by SOLVE was not stored.
The CAS has a 'radius' command, so it will not be able to directly capture the exported variable of the program. Code: EXPORT OldAAngleSetting,theta,rads,q,v; //← x isn't necessary, radius → rads Viga C | TD | FB |
06-05-2018, 03:07 AM
(This post was last modified: 06-05-2018 03:08 AM by Carlos295pz.)
If you persist in using "radius", you can evade the name resolution CAS-Home by manufacturing the data in strings before sending it to the CAS, in this way it can be done for similar cases.
Code: theta:=fsolve(EVAL("x-SIN(x)=2*q/(v*"+radius+"^2),x=3")); Viga C | TD | FB |
Thanks. Your "fsolve" equation changes also work with the "solve" command, which is what I initially wanted to do. I used "radius" to differentiate the pipe radius from the hydraulic radius "r". Geez...
