HP 82104A Card Reader Serial Numbers
06-09-2018, 08:54 PM
(This post was last modified: 06-10-2018 12:03 AM by drdbthompson.)
I've been fiddling around with 41 card readers the last week and got to wondering if there is a table of serial numbers and ROM versions floating around somewhere.
I searched Google and I search through the forum entries, but no joy. So, I thought I'd poll the membership and see if anyone knows if such a beast exists. I can confirm that unit 2704S80057 is ROM Version 1G. I can also confirm that unit 2220S80921 is ROM Version 1F. Thanks! |
06-10-2018, 04:07 PM
RE: HP 82104A Card Reader Serial Numbers | |||
06-10-2018, 04:59 PM
2018S45366
CATALOG 2 -> CARD READER No version, which means that’s the very first version. Anyway, it doesn’t work anymore. (I get MALFUNCTION or CARD ERR). I would try the abrasive red card, if I had one. Gerson. |
06-10-2018, 06:45 PM
(This post was last modified: 06-10-2018 06:58 PM by Sylvain Cote.)
You need the service module to get ROM version 1D or less.
Code: CR-1D 1945A01004 Code: CR-1E 2052S48206 Code: CR-1G 2432S80360 I think I got all of them Sylvain |
06-10-2018, 07:22 PM
(06-10-2018 06:45 PM)Sylvain Cote Wrote: You need the service module to get ROM version 1D or less. Interesting that in Singapore they switched to Rev E not later than last week of 1980, but then used some Rev D ROMs again in the first week of 1981. Could be start-up inventory issues? --Bob Prosperi |
06-10-2018, 08:15 PM
(This post was last modified: 06-10-2018 08:17 PM by Massimo Gnerucci.)
Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
06-10-2018, 08:51 PM
Yes, he is sure ...
See this thread: http://www.hpmuseum.org/forum/thread-6997.html Had that on several gadgets |
06-10-2018, 10:34 PM
(06-10-2018 08:15 PM)Massimo Gnerucci Wrote:(06-10-2018 06:45 PM)Sylvain Cote Wrote: CR-1E 2058SAre you sure about this? (06-10-2018 08:51 PM)AndiGer Wrote: Yes, he is sure ...I have re-checked the card reader and the serial number is really 2058S45227 (06-10-2018 07:22 PM)rprosperi Wrote:Maybe ... its possible that they had started the production in Singapore, then received a bunch of chip from a HP USA warehouse that they included in a later production date.(06-10-2018 06:45 PM)Sylvain Cote Wrote:Interesting that in Singapore they switched to Rev E not later than last week of 1980, but then used some Rev D ROMs again in the first week of 1981. Could be start-up inventory issues? |
06-11-2018, 02:42 AM
(06-10-2018 08:15 PM)Massimo Gnerucci Wrote:(06-10-2018 06:45 PM)Sylvain Cote Wrote: CR-1E 2058S I read in one of the books this afternoon that there was a roll-over for some units at the end of the year. So, the week 58 would mean 6 weeks into the new year, or 2106. It was a sequencing issue and this is the first instance I've seen. Weird, right? |
06-11-2018, 11:52 PM
-- Ray |
