"Choose Your KML Script" menu
07-10-2018, 07:09 AM
Why do some .KML files in the EMU48 directory not show up in the "Choose Your KML Script" menu?
I am trying to set up EMU48 v. 1.60 to run a .KML for the 50G. When I open the subject menu most of the .KML files in the directory are on the list but not all and specifically not the one I need. whutzup? |
07-10-2018, 11:04 PM
(This post was last modified: 07-10-2018 11:45 PM by Dave Frederickson.)
RE: "Choose Your KML Script" menu
(07-10-2018 07:09 AM)Arthur Kennedy Wrote: Why do some .KML files in the EMU48 directory not show up in the "Choose Your KML Script" menu? You'll need a copy of Emu48+ to run the ARM based emulations. See here: Dave |
07-11-2018, 04:00 PM
Thanks, Dave. The confusion has cleared. I was just being stupid about the use of the directory function in that menu. I was also confused by the fact that v. 1.60 is installed via the registry and + is not.
