Variable Declaration LOCAL deg:=(0);
07-19-2018, 03:44 AM (This post was last modified: 07-19-2018 03:58 AM by Gene222.)
This is the variable declaration code from the horizontal curve calculator program by CDodds.
LOCAL deg:=(0),rad:=0,tn:=0,Da:=(0);
The variables are initially assigned values of zero. However, for the deg and Da variables, the zeros are enclosed in parenthesis. What is the purpose of using "(0)" instead "0"?
LOCAL len:=0,chd:=0,ext:=0,mo:=0,rr:=0;
LOCAL sec1,seg,fil,type1:="Arc Deffinition";
LOCAL CHECK1,MENU:=0,buttonlabellist;
HCDISP();
Survey();
//BEG VC PRGM
//VARS:
LOCAL g1:=−4,g2:=6,VCSTART,STARTELEV,VCEND,ELEVEND,a;
LOCAL f,LENGTH :=1000,K1,xt,VPI:=4200,VPIE:=332.68,Elev1;
LOCAL VO2,VO1,x1,LENGTH1,STA,xt1,INT:=50;
LOCAL SSTA,l1:=400,l2:=200,n1;
LOCAL HD:=HDigits,HF:=HFormat,ENT:=Entry;
//PRGMS:
STA1();
VCHL();
VCHL1();
DATA();
UEC();
RESET();
SET();
VCHL1()
IF xt<VCSTART OR xt>VCEND THEN
//IF xt<0 OR xt>LENGTH THEN
L0:= " No Turning Point… ";
DATA;
VCHL
ELSE
L0:="High/Low Sta @ "+STA1+" - "+VO2;
DATA;
VCHL
VCHL()
IF SSTA<VCSTART OR SSTA>VCEND THEN
xt:=VCSTART;
x1:=xt-VCSTART;
WHILE xt<VCEND
DO
IF xt<VPI THEN
VO1:=f*((x1/(l1*100))²);
VO2:=(STARTELEV+(((x1/100)*g1))+VO1);
L0(0):=STA1+" - "+VO2;
xt:=-(xt MOD INT)+xt;
xt:=INT+xt;
x1:=xt-VCSTART;
ELSE x1:=VCEND-xt;
VO1:=f*((x1/(l2*100))²);
VO2:=((ELEVEND-((x1/100)*g2))+VO1);
xt:=xt+INT;
IF xt>VCEND THEN BREAK;
xt:=VCEND;
x1:=VCEND-xt;
VO2:=(ELEVEND-(((x1/100)*g2))+VO1);
L0(0):=(STA1+" - "+VO2);
ELSE xt:=SSTA;
IF xt≤VPI THEN
xt-VCSTART▶x1;
ELSE VCEND-xt▶x1;
Entry:=0;
STARTVIEW(−6,1);
EDITLIST(L0);
RESET;
STARTVIEW(−8,1);
STARTVIEW(−1,1);
//INPUT FORM 1
VC_LIST()
SET;
INPUT({g1,g2,VPI,VPIE,LENGTH,INT,SSTA},"Verticle Curves",
{" % Grade In "," % Grade Out "," VPI Sta "," VPI Elev"," Length"," Sta Interval","Special Station"},
{"% Grade In","% Grade Out","VPI Sta","VPI Elev","Length of Curve; Enter '0' for unsymetrical curve"," Sta Interval","Enter '0' to Calculate full curve at intervals"},
{g1,g2,VPI,VPIE,LENGTH,INT,0});
IF LENGTH≠0 THEN
l1:=LENGTH/200;
l2:=l1
ELSE
UEC
LENGTH1:=LENGTH/100;
a:=g2-g1;
VCSTART:=VPI-l1*100;
STARTELEV:=VPIE-l1*g1;
ELEVEND:=VPIE+(l2*g2);
VCEND:=VPI+l2*100;
K1:=(LENGTH1)/a;
f:=(((l1*l2)/(2*(l1+l2)))*a);
//HL POINT
HDigits▶n1;
HDigits:=2;
xt:=VCSTART-(((l1²*g1)/(2*f))*100);
x1:=xt-VCSTART;
IF xt>VPI THEN
//xt:=VCEND-(((((l2)²)*ABS(g2))/(2*f))*100);
xt:=VCEND-((((l2²)*g2)/(2*f))*100);
//xt:=VCSTART-(((l1²*g1)/(2*f))*100);
VCEND-xt▶x1;
ELEVEND-(x1/100*g2-VO1)▶VO2;
VCHL1;
STA1()
STA:=STRING(xt);
WHILE DIM(STA)<6 DO
STA:="0"+STA
STA:=ROTATE(STA,-HDigits-3);
STA:=STA+"+";
STA:=ROTATE(STA,HDigits+3);
DATA()
L0(0):="VPI: "+VPI;
L0(0):="VPI Elev: "+VPIE;
L0(0):="Length: "+LENGTH;
L0(0):=" ℓ₁: "+(100*l1)+" ℓ₂: "+(100*l2);
HDigits:=4;
L0(0):="Grade In: "+g1+"%";
L0(0):="Grade Out: "+g2+"%";
HDigits:=2;
UEC()
INPUT({l1,l2},"Tangent Lengths",
{" ℓ₁: "," ℓ₂: "});
LENGTH:=l1+l2;
l1/100▶l1;
l2/100▶l2
RESET()
Entry:=ENT;
HDigits:=HD;
HFormat:=HF;
SET()
HDigits▶HD;
HFormat▶HF;
Entry▶ENT;
HFormat:=1;
HDigits:=4;
Entry:=2;
//END VC PRGM
CC()
MENU:=1;
INPUT({{deg,[0],{10,40,0}},{Da,[0],{10,40,1}},{tn,[0],{10,40,2}},{ext,[0],{10,40,3}},{len,[0],{10,40,4}},{rad,[0,8],{10,40,5}},{chd,[0],{10,40,6}},{mo,[0],{60,35,6}}},"Input Curve Data",
{"△: ","D: ","T: ","E: ","L: ","R: ","Ch: ","M: "},
{" Delta"," Deg. Curve"," Tangent"," External"," Length"," Radius"," Chord"," Mid. Ordinate"},{deg,Da,tn,ext,len,rad,chd,mo});
IF deg≠0 AND rad≠0 THEN
tn:=0;
Da:=(0);
len:=0;
chd:=0;
ext:=0;
mo:=0;
rr:=0;
IF Da≠0 THEN
CHOOSE(rr,"Curve Type","Arc Deffinition","Chord Deffinition");
IF rr=1 THEN
rad:=5729.528/Da;
ELSE
rad:=5729.648/Da;
type1:="Chord Deffinition"
IF deg≠0 AND tn≠0 THEN
tn/TAN(deg/2)▶rad;
IF deg≠0 AND len≠0 THEN
len/(deg*(π/180))▶rad;
IF deg≠0 AND chd≠0 THEN
chd/2/SIN(deg/2)▶rad;
IF deg≠0 AND ext≠0 THEN
((COS(deg/2)*ext)-ext)▶rad;
IF deg≠0 AND mo≠0 THEN
(mo/(1-(COS(deg/2))))▶rad;
IF rad≠0 AND tn≠0 THEN
2*ATAN(tn/rad)▶deg;
IF rad≠0 AND len≠0 THEN
len/rad*180/π▶deg;
IF rad≠0 AND chd≠0 THEN
2*ASIN(chd/2/rad)▶deg;
IF rad≠0 AND ext≠0 THEN
2*ACOS((1+ext/rad))▶deg;
IF tn≠0 AND chd≠0 THEN
2*ACOS(chd/2/tn)▶rad;
TAN(tn)/(2*ACOS(chd/2/tn))*2▶deg;
IF tn=0 THEN
rad*TAN(deg/2)▶tn;
IF len=0 THEN
rad*deg*(π/180)▶len;
IF chd=0 THEN
SIN(deg/2)*rad*2▶chd;
IF ext=0 THEN
(rad/COS(deg/2))-rad▶ext;
IF mo=0 THEN
(rad*(1-(COS(deg/2))))▶mo;
IF Da=0 THEN
Da:=5729.528/rad;
→HMS(deg)▶deg;
→HMS(Da)▶Da;
((π*rad²)*(deg/360))▶sec1;
(sec1-((COS(deg/2)*rad*chd)/2))▶seg;
((rad*tn)-sec1)▶fil;
MENU:=1;
HCDISP;
MENU:=0;
Survey;
STARTVIEW(−8,1);
STARTVIEW(−1,1);
EXPORT Survey()
// Parameters: buttonlabellist is a list which should contain at most 6 strings for the button labels
// Returns:
// * If one of the buttons in "buttonlabellist" was pressed returns the ID (1 to 6) of the button.
// * If a button is pressed which is not labeled by "buttonlabellist" returns negative ID of the button (-6 to -1)
// * If none of the on screen buttons was pressed returns 0
IF MENU=0 THEN
RECT_P();
buttonlabellist :={"Exit","","","","V ↷","H ↷"};
IF MENU=1 THEN
buttonlabellist :={"⇨Main","","","","","H ↷"};
LOCAL selection, mouselist;
DRAWMENU(buttonlabellist);
selection := 0; //preinitialize with 0 which is returned if none of the buttons is pressed
mouselist:=WAIT(-1); // Wait until screen is touched
// Check whether one of the on-screen buttons was pressed:
IF (TYPE(mouselist)==6) THEN // Check whether we have a touch event (==list)
IF (mouselist(1)==3) THEN // Check whether a button was pressed
IF (mouselist(3) >= #DD:-16h) THEN // check whether it was one of the 6 buttons at the bottom
selection:=CEILING((mouselist(2)+1)*6/320); // Screen is 320px wide. There are six buttons. hence divide
// mouse value by 320/6. To avoid getting a value of zero when the user presses exactly at the left
//border a 1 is added to the mouse value
IF (selection > length(buttonlabellist)) THEN // Check whether a valid button was pressed.
//selection := -selection;
IF selection=6 AND MENU=0 THEN
deg:=(0);
rad:=0;
tn:=0;
Da:=(0);
len:=0;
chd:=0;
ext:=0;
mo:=0;
rr:=0;
CC;
Survey;
IF selection=6 AND MENU=1 THEN
CC;
Survey;
IF selection=5 AND MENU=0 THEN
VC_LIST;
Survey;
IF selection=1 AND MENU==0 THEN
IF selection=1 AND MENU=1 THEN
MENU:=0;
Survey;
IF selection=1 AND MENU=0 THEN
KILL;
HCDISP()
RECT_P();
//Labels
TEXTOUT_P("Delta:",G0,10,15,2,RGB(0,0,0));
TEXTOUT_P("Degree Curve:",G0,10,30,2,RGB(0,0,0));
TEXTOUT_P("Tangent:",G0,10,45,2,RGB(0,0,0));
TEXTOUT_P("External:",G0,10,60,2,RGB(0,0,0));
TEXTOUT_P("Length:",G0,10,75,2,RGB(0,0,0),100,RGB(0,255,0));
TEXTOUT_P("Radius:",G0,10,90,2,RGB(0,0,0),100,RGB(255,255,0));
TEXTOUT_P("Chord:",G0,10,105,2,RGB(0,0,0));
TEXTOUT_P("Middle",G0,10,123,2,RGB(0,0,0));
TEXTOUT_P("Ordinate:",G0,10,135,2,RGB(0,0,0));
TEXTOUT_P("Sector:",G0,10,165,2,RGB(0,0,0));
TEXTOUT_P("Segment:",G0,10,180,2,RGB(0,0,0));
TEXTOUT_P("Fillet:",G0,10,195,2,RGB(0,0,0));
//Returns
TEXTOUT_P(deg,G0,100,15,2,RGB(0,0,0));
TEXTOUT_P(Da,G0,100,30,2,RGB(0,0,0));
TEXTOUT_P(tn,G0,100,45,2,RGB(0,0,0));
TEXTOUT_P(ext,G0,100,60,2,RGB(0,0,0));
TEXTOUT_P(len,G0,100,75,2,RGB(0,0,0),100,RGB(0,255,0));
TEXTOUT_P(rad,G0,100,90,2,RGB(0,0,0),100,RGB(255,255,0));
TEXTOUT_P(chd,G0,100,105,2,RGB(0,0,0));
TEXTOUT_P(mo,G0,100,135,2,RGB(0,0,0));
TEXTOUT_P(sec1,G0,100,165,2,RGB(0,0,0));
TEXTOUT_P(seg,G0,100,180,2,RGB(0,0,0));
TEXTOUT_P(fil,G0,100,195,2,RGB(0,0,0));
//Border
TEXTOUT_P("╔",G0,0,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,7,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,14,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,21,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,28,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,35,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,42,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,49,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,56,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,63,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,70,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,77,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,84,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,91,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,98,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,105,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,112,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,119,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,126,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,133,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,140,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,147,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,154,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,161,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,168,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,175,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,182,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,189,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,196,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,203,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,210,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,217,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,224,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,231,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,238,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,245,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,252,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,259,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,266,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,273,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,280,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,287,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,294,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,301,0,2,RGB(0,0,0));
TEXTOUT_P("═",G0,308,0,2,RGB(0,0,0));
TEXTOUT_P("╗",G0,314,0,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,15,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,15,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,30,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,30,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,45,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,45,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,60,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,60,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,75,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,75,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,90,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,90,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,105,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,105,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,120,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,120,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,135,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,135,2,RGB(0,0,0));
TEXTOUT_P("╠",G0,0,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,7,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,14,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,21,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,28,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,35,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,42,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,49,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,56,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,63,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,70,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,77,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,84,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,91,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,98,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,105,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,112,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,119,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,126,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,133,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,140,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,147,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,154,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,161,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,168,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,175,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,182,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,189,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,196,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,203,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,210,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,217,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,224,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,231,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,238,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,245,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,252,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,259,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,266,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,273,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,280,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,287,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,294,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,301,150,2,RGB(0,0,0));
TEXTOUT_P("═",G0,308,150,2,RGB(0,0,0));
TEXTOUT_P("╣",G0,314,150,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,165,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,165,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,180,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,180,2,RGB(0,0,0));
TEXTOUT_P("║",G0,0,195,2,RGB(0,0,0));
TEXTOUT_P("║",G0,314,195,2,RGB(0,0,0));
//TEXTOUT_P("║",G0,0,210,2,RGB(0,0,0));
//TEXTOUT_P("║",G0,314,210,2,RGB(0,0,0));
//TEXTOUT_P("║",G0,0,220,2,RGB(0,0,0));
//TEXTOUT_P("║",G0,314,220,2,RGB(0,0,0));
TEXTOUT_P("╚",G0,0,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,7,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,14,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,21,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,28,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,35,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,42,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,49,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,56,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,63,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,70,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,77,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,84,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,91,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,98,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,105,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,112,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,119,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,126,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,133,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,140,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,147,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,154,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,161,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,168,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,175,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,182,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,189,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,196,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,203,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,210,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,217,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,224,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,231,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,238,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,245,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,252,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,259,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,266,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,273,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,280,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,287,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,294,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,301,210,2,RGB(0,0,0));
TEXTOUT_P("═",G0,308,210,2,RGB(0,0,0));
TEXTOUT_P("╝",G0,314,210,2,RGB(0,0,0));
MENU:=1;
Survey;
//WAIT(−1)
07-19-2018, 06:40 AM
RE: Variable Declaration LOCAL deg:=(0);
It should not make a lick of a difference...
Cyrille
