Pokecomgo (Sharp PC emulator on Android)
07-24-2018, 08:00 AM
(This post was last modified: 07-24-2018 09:04 AM by Pekis.)
For anyone interested, it's very simple to assemble the 64Kb binary file needed to emulate the Sharp PC-1350 on Pokecomgo, a new Sharp PC emulator on Android (see Playstore). I found the roms on the Net and according to the memory map of the 1350, you have to put cpu.rom (8 Kb) at 0000h, basic.rom (32 Kb) at 8000h and fill the rest with 0. And voilĂ ! That enjoyable emulator can also emulate other Sharp PC as the 1245, 1401, 1402, 1360, ... but you have to find the roms ... |
06-27-2019, 11:01 AM
RE: Pokecomgo (Sharp PC emulator on Android)
(07-24-2018 08:00 AM)Pekis Wrote: Hello, Hello I tried with your PC1350 rom files, but prgm PokecomGO crashed. What is install procedure? To start PokecomGO and the load rom files or you rename rom files and put them in ROM folder to see PokecomGo? Thanks in advance Toki |
06-28-2019, 07:10 AM
You have to - create a 64 Kb binary file named "pc1350mem.bin" with a binary editor - put the contents of the cpu.rom file (8 Kb) at offset 0000h - put the contents of the basic.rom file (32 Kb) at offset 8000h - put the pc1350mem.bin file in the rom folder of PokecomGO It's not that hard
06-29-2019, 06:30 PM
Hello
At the end I successfully made rom file of PC1350. Thanks for help ps do you habve the other roms? |
04-03-2020, 10:03 PM
(This post was last modified: 04-04-2020 09:50 PM by johanw.)
I just found rom files for the PC-1450 at http://pocket.free.fr/html/soft/emul_pc-1450_e.html
Download one of the zipfiles, the rom files are in the executable package. The 8kb file is the internal rom, the 32kb file the external rom. Offsets are the same here: [pc-1261/1350/1401/1402/1450] 0x0000-0x1fff : internal ROM 0x8000-0xffff : external ROM I was not alowed to attach the file pc1450mem.bin to this post, sorry. Edit: I found the roms for the 1245 and 1251 on this Github repository: https://github.com/atonizzo/sharpemu, in the rom folder. There are also files for the 1262. Storing those in pc1261mem.bin seems to work (but I didn't test very thorough). |
11-21-2020, 01:54 PM
(This post was last modified: 11-24-2020 07:02 AM by tommi60.)
The latest version of Pokecom Go (1.04.00) doesn't work on my phones for some reason, but the earlier version (1.03) is still Ok.
I managed to find the ROM images for PC-1475 (search for PockEmul source files) and after some trial and error I now have a Sharp PC-1470U up and running ![]() The ROMs for PC-1475 is: Internal ROM: cpu-1475.bin (8,192 bytes) External ROMs (each 16,384 bytes): b0-1475.bin b1-1475.bin b2-1475.bin b3-1475.bin b4-1475.bin b5-1475.bin b6-1475.bin b7-1475.bin Create two binary files, pc1470mem.bin (65,536 bytes) and pc1470bank.bin (131,072 bytes). In the smaller file you add the internal ROM into address 0x0000-0x1fff and the 8 external ROM images into pc1470bank.bin (0x0000-0x1ffff). PokecomGo can't emulate the PC-1475, that's why the renaming here to PC-1470. I don't know exactly the differences between PC-1475 and PC-1470U, but so far everything seems to work. > MEM reports 31134 > MEM$ reports 1 Edit Nov 24, 2020: Apparently the PC-1470U is "university" model of the PC-1475, and sold in Japan. Only one RAM card can be inserted in 1470U, compared to two in the PC-1475. |
11-22-2020, 08:27 AM
If someone is emulating Sharp PC-1350 with this app, then you know that there's no annunciator for DEG/RAD/GRAD shown on the screen.
The flag for this is located in memory position 787C, so you can use a short program to quickly check the flag. 10000 "A": A=PEEK &787C 10001 REM 1=DEGREE, 2=RADIAN, 4=GRAD 10010 ON A GOTO 10040,10060 10020 PRINT "GRAD" 10030 GOTO 10070 10040 PRINT "DEGREE" 10050 GOTO 10070 10060 PRINT "RADIAN" 10070 END |
11-28-2020, 07:30 AM
On the PC-1261/1262 there's a way to enter lowercase characters.
>POKE &203C, &08 Now you can switch to lowercase with <SHIFT>8 |
Search
Member List
Calendar
Help
