Bug(s) in the New Version: 2018.07.06 2.0.0.13865
07-25-2018, 10:20 PM
There is a bug in the new version of firmware:
{30,45,60,70,80,85,90}//dergrees
If I change to rad. and HP Prime is in rad. mode, no matter list or vector
{30,45,60,70,80,85,90}.PI/180// now in rads.
When I use for example in CAS mode:
sin() and copy {30,45,60,70,80,85,90}.PI/180 from the history into sin()
I get sin({30,45,60,70,80,85,90}.PI/180)
After pressing ENTER HP Prime hangs up and I have to reset it.
Strangely for cos() it works, but for tan() it doesn't (same like for sin()).
The above works in the HOME Mode.
FALSE ALARM! I 'restarted' this goddamned thing and it looks as it works. Sorry.
07-25-2018, 10:36 PM
RE: Bug(s) in the New Version: 2018.07.06 2.0.0.13865
Definitely there is a bug even after 'restart', because if in CAS I do: sin(l1)/cos(l1), I stored the input list in l1, the calc. sometimes gives the result and sometimes hangs itself, and when it does return it it HANGS ITSELF.
07-26-2018, 10:56 AM (This post was last modified: 07-26-2018 11:02 AM by Komanguy.)
(07-25-2018 10:36 PM)John P Wrote:  Definitely there is a bug even after 'restart', because if in CAS I do: sin(l1)/cos(l1), I stored the input list in l1, the calc. sometimes gives the result and sometimes hangs itself, and when it does return it it HANGS ITSELF.
Hi John,
where i try to store sin(l1)/cos(l1) into l1, the calculator doesn't hang at all.
Calculations are done correctly on my prime (real calculator)
Do you use the emulator or the physical calculator?
Guy R. KOMAN, hp 50G, hp Prime Rev. C
07-26-2018, 01:24 PM (This post was last modified: 07-26-2018 02:07 PM by John P.)
Hi Komanguy,
Store {30,45,60,70,80,85,90}*PI/180 in l1 and than do in rad. mode and in CAS sin(l1) or tan(l1) or sin(l1)/cos(l1). Mine goddamned HP Prime hangs itself every time.
Thanks for your reply.
PS
I will put the previous ver. of the firmware and see what happens.
Update:
The previous version of the firmware worked only after 'restart'.
I've reinstalled the latest firmware, did 'restart' and so far it works. Maybe the re-installation helped. I will update the post if something strange happens.
Update 2:
When I do sin(l1).^2.*cos(l1).^2 and do simplify on the result my calc. hangs itself and have to do ON+SYMB and 'restart' after. Definitely there is a bug in the firmware. With the calculations I described the HP Prime is completely unpredictable, sometimes it hangs sometimes not for a while and hangs again.
07-26-2018, 01:33 PM
(07-26-2018 01:24 PM)John P Wrote:  Store {30,45,60,70,80,85,90}*PI/180 in l1 and than do in rad. mode and in CAS sin(l1) or tan(l1) or sin(l1)/cos(l1). Mine goddamned HP Prime hangs itself every time.
No issue with my Prime & the latest firmware.
07-26-2018, 01:48 PM
Thanks Didier.
07-26-2018, 02:46 PM
(07-26-2018 01:24 PM)John P Wrote:  Hi Komanguy,
No issue here.
07-26-2018, 02:49 PM
(07-26-2018 01:24 PM)John P Wrote:  Update 2:
I do confirms. This operation hangs also on mine!
07-26-2018, 04:05 PM (This post was last modified: 07-26-2018 04:05 PM by ijabbott.)
I haven't tried that on the physical calculator yet. Note that the "2." will force an approximate result. Does it still crash if you keep the calculation "exact"?
— Ian Abbott
07-26-2018, 04:17 PM
Hi ijabbott,
"2." in sin(l1).^2.*cos(l1).^2 is, I think, for the element wise multiplication on the corresponding elements of the two list not to have approximate solution. It also crashed when I used "*". I put the dot in ".*" to make sure it will operate on the corresponding elements of the two lists.
07-26-2018, 05:28 PM (This post was last modified: 07-26-2018 05:34 PM by ijabbott.)
(07-26-2018 04:17 PM)John P Wrote:  Hi ijabbott,
I think numbers (including the decimal point ".") have higher precedence in the parser than the "." modifier. You could add a space between the "2" and the "." to be sure, or add parentheses.
Example...
In Home > Settings set Entry mode to Algebraic and turn off Textbook Display. Then in CAS mode:
Input: {1,2,3}.^2.*{4,5,6}
Displays: ({1,2,3}) .^ 2.*{4,5,6}      {4.,20.,54.}
Input: {1,2,3}.^2 .*{4,5,6}
Displays: (({1,2,3}) .^ 2) .* {4,5,6}     {4,20,54}
Input: ({1,2,3}.^2).*{4,5,6}
As can be seen, the first one with the "2." is calculated in approximate mode.
— Ian Abbott
07-26-2018, 07:54 PM
Hi ijabbott,
1.You are right that in some cases putting ".*",".-","./",".*" will give you approx. numerical results, but if I do sin(l1).*cos(l1) it doesn't.
2. If I do sin(l1).^2*cos(l1).^2 I also don't get approx. numbers.
3. (sin(l1).^2).*(cos(l1).^2) also no approx. numbers.
4. sin(l1).^2.*cos(l1).^2 it gives approx. numbers.
3. If you do trig functions on a vector or list or matrix you must use ".^" if you want the trig fn applied to each element.
4. The funny thing is that when I do what I described above I do not hang the Virtual Calculator. The VC works as expected and did not hanged itself so far. Only the physical HP Prime hangs itself. Strange.
07-26-2018, 08:16 PM
I confirm it also hangs on mine (when making sure it does an exact calculation). There is an animated hourglass in the top right corner. After a few minutes, the watchdog kicks in and the calculator does the equivalent of ON+SYMB automatically. The contents of the l1 variable are lost.
— Ian Abbott
07-26-2018, 08:26 PM (This post was last modified: 07-26-2018 08:27 PM by ijabbott.)
(07-26-2018 07:54 PM)John P Wrote:  1.You are right that in some cases putting ".*",".-","./",".*" will give you approx. numerical results, but if I do sin(l1).*cos(l1) it doesn't.
The rule (in exact mode) is that a number in floating point format (containing a decimal separator character or an exponent part) is considered to be approximate, and a number in integer format (no decimal separator character or exponent part) is considered to be exact. Mixing approximate numbers with exact numbers gives an approximate result.
— Ian Abbott
07-26-2018, 08:30 PM
Yeah, that is the good and succinct way to put it.
08-28-2018, 08:14 PM
Hello HP Prime Team,
have stated the following:
Hardware: G1 and G2
– System-wide settings
OPEN -> Home Settings (Shift ...)
CLOSE -> Home Settings (Home view key)
and NOW!
Example:
OPEN -> HP Apps -> Spreadsheet app
SELECT -> cell A1
and here is the problem!
EDIT -> =ROW
– no variables from the app variable menu can be used.
- it does not appear "ROW" but a 0.
Am I doing something wrong?
- or is it a bug?
THANK YOU!
08-29-2018, 01:39 AM (This post was last modified: 08-29-2018 01:40 AM by Tim Wessman.)
You are doing "=R*O*W" and one of those, or all 3 have a value of 0 stored in them by default.
Are you trying to access the "Row" variable? (note the capitalization)
TW
08-29-2018, 02:23 PM
(08-29-2018 01:39 AM)Tim Wessman Wrote:  You are doing "=R*O*W" and one of those, or all 3 have a value of 0 stored in them by default.
OK, the variable "Row" writing is natural. - that is clear
I want to use the variable "Row" but via the app variable menu!
- that does not work anymore, a zero appears!
– also the variable "Col" can not be used!
08-31-2018, 03:53 PM
Hello Tim,
can you check that again?
Why can not I use these variables anymore?
An HP Prime, fresh OS, is turned on.
No problem with the "app variable menu"!
Then I open the "Home Settings" and close it again.
Now I can not use the variables "Row" and "Col" from "app variable menu"!
A big mistake in the system?
08-31-2018, 04:34 PM
@Goff
I reset my Prime. Went into Home Settings. Did nothing - no changes no scrolling. Pressed Home to come out. Started the spreadsheet app. Changed cell A1 to =Row and I get the value 1.
So you need to be a bit more detailed - exact steps from a hard reset - if you want people to be able to reproduce it.
